View Poll Results: What's the number one most important factor when it comes to polishing paint?
- Voters
- 337. You may not vote on this poll
Technique
Tool
Pad
Paint
Abrasive technology
Re: POLL - What's the number one most important factor when it comes to polishing paint?
I think when I post my answer, the simple way I explain it some of you guys that think technique is the most important factor may change your minds.
hay mike, i like the poll format, thank you 4 posting
I think the abrasive technology is the single greatest factor in any paint correction project. Even a beginner to paint polishing would be able to tell the difference between a modern, high-end polishing compound vs an inferior abrasive polishing liquid. All things being equal I think a high quality abrasive will produce better results in less time and with less learning curve over a wide array of paint systems and environmental variables.
Megs105 is a high quality product but has a huge learning curve
And from what i have seen single stage paint reacts better with DAT abrasives so know what paint you are working on will affect the products used.
I am torn between abrasive technology and paint. As a relative newcomer to more advanced correction, those are the two things I focus on most. While all of them have to be considered I still worry about what paint I'm correcting and it's condition and am I choosing the right abrasive. My Flame Red Jeep required a different approach from my dad's white Tundra even though at first glance the paint condition appeared similar. My test spots showed otherwise for correction method. Just my $.02 as I am still learning.
FWIW I voted for abrasive technology only because I now have 10 different abrasive products when I only had 2 before I joined here and bought a DA.
Never said anything about M105. And the very first time I used it, it created an amazing finish and I was completely satisfied with the product. The only reason I know there is a learning curve with M105 is from reading about other people's challenges with the product.
I agree that with experience you'll be able to make informed tool/pad/product choices for maximum results. But especially with novice users a higher quality, modern abrasive technology will be easier to use and produce better results than the compounds and polishes of yesteryear.
I say technique because you can have the best of everything but if you don't know how to use it, well, there you are 👈
2022 Elantra N Cyber Gray
I used 105 cause it is a good quality product that everybody knows but has given alot of people troubles at first. And to be honest you are first person I have seen that has said it worked flawless the very first time you used it. Not doubting you
What makes everyone choose what product,tool,pad and technique you are gonna use?
Last Post: 07-17-2020, 09:16 AM
Last Post: 07-17-2020, 09:11 AM
By Nick McKees37 in forum Auto Detailing 101
Last Post: 02-10-2015, 12:36 PM
By Flannigan in forum Tricks, Tips and Techniques
Last Post: 05-09-2012, 06:27 AM
By crxman2010 in forum Motorcycle Care
Last Post: 03-05-2012, 09:49 PM
