View Poll Results: What's the number one most important factor when it comes to polishing paint?
Voters
337. You may not vote on this poll
  • Technique
    186 55.19%
  • Tool
    10 2.97%
  • Pad
    8 2.37%
  • Paint
    43 12.76%
  • Abrasive technology
    90 26.71%
Page 13 of 21 FirstFirst ... 3456789101112131415161718192021 LastLast
Results 121 to 130 of 208
  1. #121
    Super Member StephenK's Avatar
    Jul 2006
    Rochelle, Illinois
    1,589
    Re: POLL - What's the number one most important factor when it comes to polishing paint?
    When this poll started i said paint was the most important and i have listed multiple reasons why as well as a couple articles by some top people in this industry.
    Since this thread as grown and basically paint as been taken out of the factor due to the fact that the paint is gonna be able to be polished.
    Now there is no need to even consider the paint anymore. The chemical companies have really stepped up their game since there has been a lot of change to automotive paint through out the years they have had to keep up and change their products.
    IMO there are 3 companies that have kept up with the change of paint technology and that is Griots BOSS line, HD, and Optimum.
    As long as i have any of these 3 in my arsenal i feel i can conquer any vehicle that comes my way. For me these 3 are very easy to use.
    So i will reluctantly go with abrasive technology.
    Just keep in mind products companies changed their formulas cause they had to due to changes in the paint.
    Which shows their first thought was "whats gonna work on this paint.?"
    Hi my name is Steve and I am a Griotsaholic
  2. #122
    Oct 2009
    493
    If people were achieving show car results before 2016 products then it cant be the products that are the most important.
  3. #123
    Jul 2006
    Rochelle, Illinois
    1,589
    Quote Originally Posted by JeffM View Post
    The products are always changing because paint it always changing. Products that gave best results in 2000 on a 2000 or older vehicle may not work the same on 2016 paint.
  4. #124
    Super Member VR8's Avatar
    Dec 2008
    Lynchburg, VA
    524
    Although I rate them all VERY important to a great result, TECHNIQUE makes all of the others perform their best.
  5. #125
    Super Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Quote Originally Posted by VR8 View Post
    Everyone keeps answering this question.
    But the fact that abrasive technology is a option of choice, that automatically means if you choose another option that you are not using a quality compound.
    You can have the best polisher, pad, technique, and if the polish isnt a quality one the job is going to be bad.
    So i have to agree with Mike that abrasive technology is the number one most important in polishing.
    With all the new awesome advancements in compounds sometimes we forget the older compounds how they were like Mike says "Caveman Compounds" rocks in a bottle type of abrasive.
    Again you can have all the best of anything if you don't have a quality polish the paint isnt going to look good to modern day standards.
    I will make an analogy: a race car driver is good at what he does and is a master at his craft and technique, however if his motor isnt fast and running on all cylinders his technique and skills mean nothing.
  6. #126
    Quote Originally Posted by StephenK View Post
    Well it is the stuff that actually "touches" the paint.
    Agreed. I was calling on body shops and detail shops starting in 1987 and back then the only really good abrasive technology that worked on clearcoats was the (new back then), Meguiar's #2 Hi Tech Fine Cut Cleaner and #9 Hi Tech Swirl Remover.
    Holograms were a huge problem back then, still are but not due to a lack of good products.
    There's still a wide range of abrasive quality on the market, that is good and less good, so test anything you're going to use if you've never used it before and black paint is the best color to test on.
  7. #127
    Super Member Jomax's Avatar
    Jan 2012
    Arizona
    1,422
    Abrasive technology. No matter what technique I do, if I don't have the right product it comes out sub par. I change the compound to something else, and bam. It's coming out amazing.
    David 2000 Ford F-350 DRW CCLB BLACK/GOLD
    Wish list:
    Everything Mike has in his garage for detailing
  8. #128
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    I recently used the M02, and M09 combo. While the results were satisfactory, they were not quite able to be had as easily, or to the level the modern polishes give me.
    Granted this is the original 1978 paint on this Dodge. I used M02, M09, and M20.
    Attached Thumbnails Attached Thumbnails POLL - What's the number one most important factor when it comes to polishing paint?-1465959993030-jpg
  9. #129
    ***Update***
    This is my first day back in the office since doing the Competition Ready 3-Day Detailing Class Roadshow at the Indianapolis Motor Speedway.
    We worked on some AMAZING cars both in the class and at the Museum for our TV show. We worked on both modern basecoat/clearcoat paints and old school single stage paints. More than ever I'm convinced that the MOST important FACTOR when it comes to polishing paint is the abrasive technology.
    Technique is important (of course), so is using the right tool for the job as well as the correct pad for the procedure. But the thing that touches the paint first is the abrasive technology. It's either good and it works or it's bad and it doesn't work and you can throw GREAT technique at bad abrasive technology all day long but at the end of the day, it's not going turn bad into good.
    Love all you guys that think technique is the most important factor but my experience shows otherwise.
    Also just to note, at this class at the Competition Ready 3-Day Detailing Class Roadshow at the Indianapolis Motor Speedway, we used ALL SONAX products and SONAX compounds, polishes and cleaner/waxes use GREAT abrasive technology as as such, ALL the cars we worked on including two Dusenberg's, worth over a million dollars each and one with single stage and one with basecoat/clearcoat paints systems came out flawless. And the end results start with the the stuff that's actually touching the paint.
  10. #130
    Cool old truck.
    Back in the late 1980's through to the mid-2000's the #2 Fine Cut Cleaner and the #9 Hi Tech Swirl Remover were the best products in their class for AT THE TIME the NEW basecoat/clearcoat paints systems being introduced to the market.
    These were the two first products that didn't simply scour the early clearcoat paints back then.
    It's too bad all my old Meguiar's friends that like me were calling on body shops back then don't post online. I think I'm the only guy left that remembers all this stuff AND posts online. Not just Facebook, which everything disappears in a matter of minutes but in the forever forum world.
    Now days they are better than nothing but there's better options available. Even in Meguiar's own line.
    And I know this from first hand experience as I worked for Meguiar's when the #2 and #9 Tag Team were introduced to the market. I even have the catalogs that introduced this "new at the time" system.
    I did THOUSANDS of demonstrations showing,
    Nikken Finishing Papers
    #2 Fine Cut Cleaner with wool and foam pads
    #9 Hi Tech Swirl Remover with foam pads
    #26 Hi Tech Yellow Wax
    And again, back then it was the best and most consistent system on the market.
  1. Replies: 14
    Last Post: 07-17-2020, 09:16 AM
  2. Vindication - What's the most important factor when it comes to polishing paint
    Last Post: 07-17-2020, 09:11 AM
  3. Car Detailing Poll - Your feedback is important!
    By Nick McKees37 in forum Auto Detailing 101
    Last Post: 02-10-2015, 12:36 PM
  4. Why Paint Cleaners are Important
    By Flannigan in forum Tricks, Tips and Techniques
    Last Post: 05-09-2012, 06:27 AM
  5. Harley Factor Bags - Paint Correction
    By crxman2010 in forum Motorcycle Care
    Last Post: 03-05-2012, 09:49 PM
