Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 67
  1. #41
    Mar 2014
    Columbia, SC
    71
    Re: How to use the Dr. ColorChip Paint Chip Repair Systems
    Mike,
    Thank you for the detailed how to on the Dr. ColorChip system.
    I recently evaluated a clients vehicle and found numerous rock chips around the car , from tiny to kind of large rock chips. The issue is that, there is rust on the metal.
    How would you clean and prep the area to be touched up? IronX? 2000 grit wet dry sandpaper on a pencil eraser? Then clean with IPA? And proceed as usual?
    I see that you mentioned to first polish the vehicle before performing chip repairs.. Will the chips affect or harm the polishing pads at all?
    You mentioned your experience at Meguiar's where the bill was 60-75$. Since I will be ordering a ColorChip package and they normally are ~50$, how do I base the cost of work ontop of that 50$? Would I charge them for the cost of the supplies since it's dedicated to their vehicle, and keep the color for possible future same color cars?
    Thank you!
    Stephan
  2. #42
    Quote Originally Posted by Oceans05 View Post
    Mike,
    Yes to all of the above but keep in mind if you use Iron X be sure to rinse very thoroughly after using it and chances are as the bare metal dries a little rust flashing will return so you'll still have to remove this trace rust before applying the touch-up paint.
    Nope... not even an issue...
    You mentioned your experience at Meguiar's where the bill was 60-75$. Since I will be ordering a ColorChip package and they normally are ~50$, how do I base the cost of work on top of that 50$? Would I charge them for the cost of the supplies since it's dedicated to their vehicle, and keep the color for possible future same color cars?
    Thank you!
    Stephan
    Two ways to go about this...
    1. Make the customer order and get their own Dr. ColorChip repair kit. The cost incurred is their cost and part of owning a rock chip free car. This is the best approach.
    2. Start a dedicated business doing rock chip repair and purchase the business start up kit from Dr. ColorChip. Check with Dr. ColorChip about this option.
    When I do this, and I have two cars coming up, I simply share the website with the customer and tell them to get the kit for their paint code on their car.
  3. #43
    Jul 2013
    80
    Nice to see that this system isn't just a gimmick, and that it actually works. I just ordered a kit today. Thanks for the writeup.
  4. #44
    Aug 2015
    Hey everyone. Newb here. Sorry to bring up an old thread, but, I have a question about layering Dr. Colorchip.
    When you layer, do you do the entire process (paint, dry, wipe, repeat as necessary) or are you applying multiple layers and then wiping at the end?
  5. #45
    Mar 2014
    Columbia, SC
    71
    Hey, just a follow up, crazy how it's a year later...
    Thank you for posting the Dr. Color Chip videos on You Tube! They have helped a lot and I will check to see about their mobile detailer package!
    Stephan
  6. #46
    Super Member AeroCleanse's Avatar
    Nov 2008
    Neenah, WI
    2,422
    Does AG sell the commercial kits or just the DYI ones?
  7. #47
    Sorry I just found these posts...
    Quote Originally Posted by swexlin View Post
    You're welcome. How did it go for you?
    Quote Originally Posted by IndyPilot View Post
    You would apply multiple layers until you were happy and then do the wiping process.
  8. Likes 6od liked this post
  9. #48
    Quote Originally Posted by AeroCleanse View Post
    Long time no see you post AeroCleanse... nice to see you back.
    The answer is at this time we only offer the Do-it-Yourselfer Kits.
    On Autogeek.com
    Dr. ColorChip Road Rash Complete Paint Chip Repair Kit
  10. #49
    Newbie Member icehole2001's Avatar
    Feb 2007
    Los Angeles
    Are there any tips for using the system on curved panels? I found this video on YouTube, but it's really short and doesn't show the final result. The chips on my car are nowhere as large, about 1/2" in length, and are on the wheel arches and another where the fuel filler curves into the recess of the body like the previous owner nicked it with the pump nozzle.
    https://www.youtube.com/watch?v=50CmCujhRjI
    I guess what I'm asking is if there's maybe a benefit to letting the paint set longer so it's harder or techniques to not pull all the paint out of the chip when wiping with the blending solution. I have the kit in my possession and am going to do the touch up soon.
    Thanks in advance!
  11. #50
    Quote Originally Posted by icehole2001 View Post
    Thanks in advance!
    You can let the paint dry longer, it won't cause problems.
    You can use the Sealact to remove the paint it's just the longer it dries the more you'll have to rub and the more Sealact you'll have to use.
    You could let the paint dry for a couple of days if you want.
  1. NEW - Dr. ColorChip Paint Chip Repair Systems
    By Dwayne in forum New Car Care Products
    Last Post: 08-21-2015, 07:51 PM
  2. Paint Chip Touchup Repair systems?
    By Tekken in forum Auto Detailing 101
    Last Post: 03-15-2015, 07:58 PM
  3. Dr ColorChip paint chip repair kit
    By beercanbilly in forum Ask your detailing questions!
    Last Post: 03-05-2012, 08:50 AM
  4. DR. ColorChip Vs Langka paint chip repair
    By unclestu in forum Auto Detailing 101
    Last Post: 08-19-2009, 10:01 PM
  5. Paint Chip Repair, Dr. Colorchip?
    By tamvegas in forum Auto Detailing 101
    Last Post: 02-17-2007, 02:18 PM
