Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Sanding Wood with a Porter Cable DA Polisher
    Before
    It's on end in this picture but I think it's standing about 7' tall.
    A few years ago I was given a very large desk that I really like except it has some bad stains in the wood.
    So to try to salvage the finish I sanded it down using my Porter Cable DA Polisher as it was originally intended to be used and that's as a wood sander.
    I taped-off and sanded the desk using #220 grit discs using my Porter Cable DA Polisher. This took all the work out of it as compared to sanding by hand. There were some pretty bad stains in one area that I couldn't sand all the way out.
    2-Coats of MINWAX Red Mahogany 225
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    Re: Sanding Wood with a Porter Cable DA Polisher
    Thats some serious work. Cars are way easier, lol. I wouldn't have thought 220 grit would be enough for those stains. Very nice work. Has anyone ever said you have real talent?
    Semper Fi
    Ralph
    Nov 2011
    600
    Quote Originally Posted by rmagnus View Post
    He was probably practicing the "least aggressive" approach since the top is probably veneered. Just like clear coat, you can sand thru the face veneer, and just like clear coat you seldom know how thick the veneer is. Some mills are peeling thinner than 1mm veneers from logs these days.
    Super Member Anthony@zerboautoworks's Avatar
    Nov 2012
    Tampa,FL
    789
    I used to have one of those older desks in the office, let me tell you Mike that desk had some serious weight for a desk.
    Apr 2013
    Thanks. I was wondering if this was possible. Clearly it is.
    Super Member mwoolfso's Avatar
    Jul 2011
    Long Island, NY
    2,592
    I stand corrected. :-)
    Super Member Boudin's Avatar
    Mar 2012
    Southeast Louisiana
    453
    So when are you going to polish the wood with some M205?
    Super Member zmanjohn's Avatar
    Mar 2013
    Clemmons, NC
    318
    Mike, is there anything you can't do? Now for the polish.
    Feb 2011
    Minot, ND
    12,365
    Nice work Mike.
  10. #10
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    Mike,
    Your woodwork looks great and shows folks what this machine was designed for in the first place.
    I also used mine for its original purpose about 12 years back. It worked wonderfully with the supplied sanding pad that came with the old PC 7336.
    In short, foundation shifted and doors would not close properly. The PC and that single pad took care of all solid doors. I was amazed how little effort it took, how much dust it made, and how well the doors closed afterwards.
    Rick....now in North Texas
  1. Porter Cable/Trizact Sanding Stripes
    By KenRobertson in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-21-2017, 11:24 AM
  2. Porter Cable and Color Sanding
    By hernandez.art13 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 05-01-2013, 11:19 AM
  3. Porter cable for wet sanding
    By kingweb50 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 11-17-2012, 12:58 PM
  4. Using a Porter Cable 7424xp to wax wood furniture
    By myculito in forum Ask your detailing questions!
    Last Post: 06-16-2011, 03:24 PM
  5. Porter cable for wet sanding??
    By Jrgs-r in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-15-2011, 04:22 PM
