Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,769
    Re: Video: Mark your backing plate to make it easy to see pad rotation
    I would like to respectively add that I mark my backing plates on two sides (180 degrees from each other).
    I find this to be even easier to monitor.
    JMO....
    Mar 2017
    Southeastern PA
    2,480
    JMO....
    I also add more than 1 mark. My OCD does not like the lack of symmetry when adding just one line.
    Bruno Soares
  3. Thanks PaulMys thanked for this post
    Likes astro liked this post
  4. #13
    Quote Originally Posted by BSoares View Post
    That's how I started out doing, it. I would place 4 marks on the backing plate and the pad.
    Pad Saturation Signs
    The above is from a "reply" I posted to MeguiarsOnline.com back in May of 2009.
    Back then, the idea of marking your backing plate or marking your pads was a "new" idea.
    BUT - also LOOK at how THICK the Meguiar's foam pad was back then? We didn't get THIN pads until Lake Country introduced their thin Hydro-Tech foam pads back in September of 2010.
    Here's my article on that and you can see the time stamp of the first post in the thread.
    Thin is in...
    Hard to believe that while the first foam pad was introduced in 1965 it took 54 years to get to thin pads.
    Car Wax History
  5. #14
  6. #15
  1. 5 inch backing plate for the Rupes Mark II LHR21
    By RMarkJr in forum Ask your detailing questions!
    Last Post: 03-22-2017, 06:14 AM
  2. 5" backing plate on the lhr21 mark 2
    By Xplosive Detail in forum RUPES BigFoot Oribital Polishers
    Last Post: 09-05-2016, 09:41 PM
  3. Mark Your Backing Plate - Makes it easy to see Pad Rotation
    Last Post: 04-30-2012, 10:37 AM
  4. How-To: Make Your Own Rotary Backing Plate Extension!
    By opie_7afe in forum How to Articles
    Last Post: 12-04-2011, 09:33 PM
  5. Replies: 8
    Last Post: 10-25-2011, 07:47 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
