» Detailing Classes
Page 10 of 10 FirstFirst 12345678910
Results 91 to 95 of 95
  1. #91
    Mar 2017
    Re: How to Mix IPA for Inspecting Correction Results
    Incredible, thank you so m uch
  2. #92
    Mar 2017
    thank you so much, this is amazing and i find it very helpful. :D
  3. #93
    Aug 2017
    Sanford NC
    Quote Originally Posted by Godspeed View Post
    Another great article by Mike! Thanks for taking the time to explain what we are exactly doing to our paint. And more importantly, what the IPA is doing to our paint chemically.
    For those of you like me, who have a few different size spray bottles, here is the math to figure out your total percentage of IPA in your mix.
    X(Y/Z)
    Where
    X= The percentage of your IPA
    Y= Amount of IPA in ounces added to your spray bottle
    Z= Total volume of spray bottle in ounces
    Let's use Mike's formula as an example. 4oz of 91% IPA in a 32oz spray bottle gives us a total percentage of IPA of 11.3%.
    .91(4/32) = .11375 or 11.357%
    So if we were to use a smaller, say 22oz bottle we can now figure out how much IPA to add to achieve our target of 10%.
    .91(3/22) = .12409 or 12.409%
    So, we get 12.4% IPA when we use 3oz of 91% IPA diluted in a 22oz spray bottle.
    To add to Godspeed's great explanation, I will attempt to complicate it.
    Have you ever been in a position where you knew what dilution % you wanted to achieve, but didn't' know how much IPA to add to the water?
    (YZ)/X=
    Where
    X= The percentage of your IPA (ex. .5 = 50%)
    Y= Dilution ratio you want (ex. .5 = 50%)
    You have 91% IPA in a 32oz spray bottle and you want it diluted to 10%.
    Simply put (.10x32)/.91= 3.5oz; you would need 3.5oz of IPA in the 32oz bottle. Fill it up with some water and boom! 10%
    Fiddle around with it; it's super easy and super fun!!!
    Check on learning
    How many ounces of IPA would I need I have 75% IPA with a 16oz bottle and I want it diluted to 25%?
  4. Thanks belior thanked for this post
  5. #94
    Senior Member theblob640's Avatar
    Mar 2013
    550
    Quote Originally Posted by TrueColor View Post
    (YZ)/X=
    Where
    Check on learning
    ~5.3 oz, thanks for that. Good information!
  6. Likes TrueColor liked this post
  7. #95
    Mar 2019
    "50% IPA
    To mix a 32 ounce Spray Bottle
    8 ounces, (or ˝ of a 16 ounce bottle) will make 32 ounces of 12.5% IPA to Water solution. Get a 32 ounce container and pour in 8 ounces, (or ˝ of a 16 ounce bottle) of the 50% IPA then fill the container up with water and you get 32 ounces of 12.5% solution."
    I think with 50% IPA, will just mix 50/50 with water which results to 25% solution. Then, transfer half of this 25% solution to another bottle then simply mix again with water 50/50, so it will yield to 12.5% solution right?
  1. Replies: 9
    Last Post: 12-18-2017, 08:23 PM
  2. M34 to check final correction results?
    By Zedhead07 in forum Auto Detailing 101
    Last Post: 10-06-2011, 02:48 PM
  3. First Correction - Poor Results - Any Advice?
    By Soulman1980 in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-11-2011, 10:19 PM
  4. Quick Results from Meguair's DA Microfiber Correction System
    By DonMTV in forum Auto Detailing 101
    Last Post: 04-06-2011, 04:17 PM
  5. Interesting results from new Meguiar's Microfiber DA Correction System
    Last Post: 12-03-2010, 04:57 PM
Members who have read this thread: 87
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
