» Detailing Classes
Page 29 of 31 FirstFirst ... 19202122232425262728293031 LastLast
Results 281 to 290 of 304
  1. #281
    Senior Member Eric7810's Avatar
    Mar 2019
    102
    Re: The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
    I'm just here to give a huge THANK YOU for this incredible write up. As a beginner, I learned so much.
    Loving this forum!
  2. #282
    Jun 2009
    Stuart, Florida
    49,351
    Quote Originally Posted by Eric7810 View Post
    Loving this forum!
    Why thank you!
    And I just replied to your question here using information from the first page of this thread.
    Can center caps be corrected?
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  3. #283
    Member
    Mar 2015
    Eagan, MN
    61
    Would this technique work on aircraft paint to remove oxidation? Also could you do an ipa wipe after the polishing step, then apply a coating?
  4. #284
    Jun 2009
    Stuart, Florida
    49,351
    Quote Originally Posted by Jeremy5431 View Post
    Yes but - I would only do this treatment if the paint on the aircraft were ANTIQUE.
    If it's a modern aircraft that simply has oxidized single stage paint then get a good one-step cleaner/wax like BLACKFIRE One Step, some foam pads and an orbital polisher and go to town.
    Also - if it's chalky white paint - consider using the "Cheater Technique" I use to know down the loose dead paint during the wash job and then hit it with the BLACKFIRE One Step. That's what we did with the original single stage paint on this classic Cadillac.
    The COMET Technique by Mike Phillips - 1965 Cadillac - Original Single Stage Paint - Slam job by Mike Phillips
    BEFORE
    AFTER
    The short answer is, "yes" but there are caveats, see what I wrote here,
    Can you apply a ceramic coating to old school single stage lacquer paint?
    What are you working on?
    Twitter
    Instagram
  5. #285
    Member
    Mar 2015
    Eagan, MN
    61
    There are a couple of planes. I was asking about #7 as a more general question.
    Both plans are very well cared for without oxidation.
    The first is an extra 300 L that has light swirls. Iím thinking my new RUPES 15 m3 with a white pad and ultra fine polish should do the trick.
    The other one is a bit more ďfunĒ itís a P51 Mustang that is polished aluminum.
    This belongs to a friend of mine. We polished it a long time ago by hand. I have to think that there is s better way. Iím wondering if my RUPES DA would be a good choice or if I should look at the 3401 or a rotary?
    This is a bit off topic so feel free to move to a new thread
  6. Likes PaulMys liked this post
  7. #286
    Jun 2009
    Stuart, Florida
    49,351
    I’m wondering if my RUPES DA would be a good choice or if I should look at the 3401 or a rotary?
    First - those planes are SWEEEEET!
    Second - I think the RUPES would be a good choice or any free spinning orbital. With painted planes you have rivits and high edges from overlapping aluminum panels and these two things, because they stick up tend to get the paint burned off. So you want to stick with the more gentle tools i.e. free spinning orbitals.
    Most of the RUPES tools are free spinning except their rotary and the Mille.
    I would thing a RUPES 15 or 21 would be fine.
    I think and even simpler Porter Cable - 8mm free spinning would do the job too....
    I'd highly take a look at the BLACKFIRE One Step as an option. Very nice one-step cleaner/sealant that also wipes of super easy. When detailing LARGE things you normally want to knock it out in one step and for sure want a product that does NOT micro-mar the paint and wipes off easy.
    I talk a LOT about abrasive technology in my detailing classes and on this forum because it's IMPORTANT. I wrote this article yesterday after testing two different AIOs or cleaner/waxes. They don't use good abrasive technology.
    Pictures of Micro-Marring - DA Haze - Tick Marks - Compounds - Polishes - AIOs - Clearcoat Paints
    Twitter
    Instagram
  8. #287
    Member
    Mar 2015
    Eagan, MN
    61
    Hey Mike
    Looks like the link didnít work
    Luckily I do have a porter cable as well! What metal polish would you recommend that can be applied by machine?
    My friend has a World War II aircraft museum up here in Minnesota. Hereís a few more from their collection
    If your ever up in Minnesota, let me know and I might be able to get you in one
  9. Likes PaulMys liked this post
  10. #288
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    7,858
    Am I seeing a P-51, and a B-25 there, Jeremy?
  11. #289
    Member
    Mar 2015
    Eagan, MN
    61
    Yes there are two P51s and a p-38 lightning, a few P-40s, a wildcat and a Corsair. Thatís not the whole list either.
    Also they purchased a German rail box car that was used move prisoners and brought it to the museum.
  12. Thanks PaulMys thanked for this post
  13. #290
    Jun 2009
    Stuart, Florida
    49,351
    Twitter
    Instagram
  1. Replies: 12
    Last Post: 03-05-2019, 05:24 PM
  2. removing oxidation on single stage paint. Cleaner of Final cut polish
    By 2shiny in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-18-2013, 06:52 AM
  3. Replies: 12
    Last Post: 11-19-2012, 12:57 PM
  4. The practical differences between a single stage paints and clear coat paints
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 05-01-2012, 08:47 AM
  5. Replies: 7
    Last Post: 08-23-2010, 03:40 PM
Members who have read this thread: 46
» January 2021
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
