Page 25 of 32 FirstFirst ... 151617181920212223242526272829303132 LastLast
Results 241 to 250 of 314
  1. #241
    Jul 2015
    Re: The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
    Hi Mike,
    Once again, thank you for a very good article.
    I followed this guide and polished my Dodge Wayfarer Business Coupe '49 during this winter, and I am quite satisfied with the results.
    The picutres don't justify the amazing results, but nevertheless, here are a few pictures.
    Attached Thumbnails Attached Thumbnails The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints-img_1792-jpg   The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints-img_1796-jpg   The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints-img_1789-jpg
  2. #242
    Jul 2015
    ... I have attached two more pictures, one a close up of one of the fenders - and the other one showing the edge near the front window. I am interested in how you would treat these areas on a car that shows signs of rust.
    EDIT: it is hard to see when the picuters get uploaded, will try to get some better picutres and upload during the weekend.
    Attached Thumbnails Attached Thumbnails The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints-fender1-jpg   The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints-img_1794-jpg
  3. #243
    Quote Originally Posted by Vifa View Post
    I'd rub them down with the number #7 and do the best you can then seal with wax and enjoy the ride. Not more you can do outside of trying a compound and if you do this becarful you don't rub through the paint to primer or steel.
    I think you're "Attaching" your images. Try "uploading" them to your gallery and then "insert" them. That's how I do it and while it takes a little thinking to figure it out I do have how-to articles on this topic and I can even help you to figure it out.
  4. #244
    Jul 2015
    Hi Mike,
    Thank you for your reply, I have tried to upload some better pictures (hope this will work :-) )
    This picture shows the edge at the roof above the driver's door.
    As you cleary can see, a lot of 'rust' has gathered here through the years.
    Here is a picture of my right front fender..
    ...and a close up:
    How would you treat the fender ? - and would you still use #7 to remove the rust in the first picture ?
    ...and should I be concerned when I rub out #7 on my left front fender when it looks like this ?
    Thanks for the tip about uploading pictures instead - seems to work - and thank you for your time.
    Best Regards
  5. #245
    Super Member 57BORNTORUN's Avatar
    Jul 2012
    Palm City, Florida
    1,554
    "As you cleary can see, a lot of 'rust' has gathered here through the years."
    Try IRON-X on the rust then put on a top coat of your liking.Just putting off the inevitable. Now-a-days it`s called PATINA.
    "Chrome wheeled, fuel injected and steppin' out over the line"
  6. #246
    Hi Mike,
    First, thanks for getting back to me...
    Second, just this last week I shared a tip on cleaning out the drip rail on classic cars and streetrods before machine polishing, here's the link to what I wrote on our Competition Ready Facebook page.
    Air currents
    While the tip doesn't specifically apply to what you're trying to do it does apply to working the area you're going to work and that's the drip rail.
    The rust you show inside the drip rail is common on old cars with old paint and here's what I would do. I would get a piece of terry cloth toweling, that is take a terry cloth bath towel, hand towel or wash cloth and cut out a chunk about 5" square.
    Fold this piece of terry cloth in half and then dribble some #7 into the channel of the drip rail and then start rubbing the piece of terrycloth along the inside of the drip rail.
    This will do three things,
    1. Loosen and remove any loose paint that are chipping off. This is to be expected and by removing any loose paint you can now get to the surface below to clean and polish it.
    2. Remove any rust residue. You'll have to rub a lot as surface rust on metal doesn't come off as easily as oxidized paint.
    3. Restore a polished surface to any paint left inside the drip rail.
    Then like the rest of the car, simply maintain this area using the same technique.
  7. #247
    Jun 2016
    Hello Mike,
    What do you recommend using instead of the M80 speed glaze? I think it is discontinued as I cannot find it anywhere.
    John
  8. #248
    Quote Originally Posted by JuanCappuccino View Post
    Hello Mike,
    John
    Hi John,
    I created for you, your very own thread. When you tag a question onto a thread that already has over 200 replies and almost 4 hundred thousand views it can get kind of lost.
    Here's the link to your thread and I've posted a lot of info to help you restore the original paint on your 1969 Oldsmobile 98
    How to restore original paint on a 1969 Oldsmobile 98
  9. #249
    Jun 2016
    Dear Mike,
    Can you tell me what to use instead of the M80 speed glaze as it does not appear to be available any longer and is no longer on the McGuiar's website.
    All the best,
    John G.
  10. #250
    Jun 2016
    Dear Mike,
    All the best,
    John G.
  1. Replies: 12
    Last Post: 03-05-2019, 05:24 PM
  2. removing oxidation on single stage paint. Cleaner of Final cut polish
    By 2shiny in forum Ask your detailing questions!
    Last Post: 09-18-2013, 06:52 AM
  3. Replies: 12
    Last Post: 11-19-2012, 12:57 PM
  4. Replies: 6
    Last Post: 05-01-2012, 08:47 AM
  5. Replies: 7
    Last Post: 08-23-2010, 03:40 PM
