Results 21 to 30 of 38
  1. #21
    Re: RIDS and Feathersanding - A Highly Specialized Technique by Mike Phillips
    Quote Originally Posted by jbgrant View Post
    Bump. Photos?
    You mean the red x's?
  2. #22
    Jan 2010
    Red x's... yeah, I viewed the photos when this first was posted, but just wanted to take a look again now that I have the "same" car to work on.
    Maybe they linked to another site that no longer hosts them... they are no longer on any company's site from what I see.
  3. #23
    Quote Originally Posted by PA 2 IL View Post
    Those photos are hosted on the Meguiar's Online Photo Gallery. Meguiar's recently upgraded their vBulletin software to the newest version and since the upgrade all the photos in the first gallery are now red x's.
    I e-mailed Mike Pennington about the issue last night and I'm sure they have one of their IT guys investigating. I hope they find a fix as I have almost 4000 photos hosted on the MOL photo gallery and they are shared all over the Internet.
  4. #24
    Jan 2010
    Sounds like it's being worked on... thanx!
  5. #25
    Super Member Kaleb G.'s Avatar
    Jan 2011
    Normal, IL
    370
    Hey jbgrant, I'm from PA, but live in IL now... we go to Bloomington all the time for the restaurants.
    What part of IL do you live in? I'm right in the middle in Normal.
  6. #26
    Jan 2010
    Kaleb-
    Well, I'm in Marshall, IL, so we go to Bloomington, but actually Bloomington IN, to go out for dinner, etc. since good old Terre Haute gets old pretty quickly. We do get to Champaign once in a while also.
    - Josh
  7. #27
    Jan 2010
    NICE! The images are back up. Man that's stellar - shows where to tape off the e34, what the sanding process looks like... I hope mine turns out half as good as that M5! Thanks Mike!
  8. #28
    Super Member Ron Atchison's Avatar
    May 2011
    Illinois
    1,034
    Just had to post this for you Mike. Not everything is gone you just have to know how to find it.
  9. #29
    Jun 2011
    2,711
    Quote Originally Posted by O.C.Detailing View Post
    Hey Mike, if I make a bottle specifically for a wet-sanding spray solution, should I just use 2-3 drops of car wash soap for the entire bottle or use a teaspoon or two of the car wash shampoo?
    I do have a bottle, but I believe I used too much soap based on what you're saying. This post is some awesome information. It's amazing the kinds of things you don't think about (like cutting sand paper into small pieces) when you get into the heat of the moment trying to remove a few RIDS.
    I've been using a form of your feathersanding when I wet sand, but not to the specific directions you provided here. I'll start using your method as it makes a ton of sense and will hopefully make removing the sanding marks and scratches a lot easier.
    Thanks for the informative post.
    Bump...in case Mike never read the above post.
    Bill
  10. #30
    Quote Originally Posted by Hoytman View Post
    Thanks Bill....
    Just a drop or two for a 32 ounce spray bottle of water. You want just enough soap to provide lubrication plus anit-loading of the disc with paint particles but you don't want to create suds as you sand.
    I've been using a form of your feather sanding when I wet sand, but not to the specific directions you provided here. I'll start using your method as it makes a ton of sense and will hopefully make removing the sanding marks and scratches a lot easier.
    Glad it helps....
    For everyone reading this into the future, keep in mind when I wrote this article and used this technique products like the 3M #3000 and #5000 Trizact Sanding Discs had NOT been invented yet.
    Dampsanding with 3" Griot's Garage Mini Polisher
    Griot's 3" Mini Polisher works great as a 3" Dampsander
    Nor had the Rupes TA50 been introduced yet.
    Rupes TA50 Mini Sander - First look...
    Rupes TA50 Removing RIDS
    Precision Buffing with the Rupes TA50 - It doesn't get any better than this!
    Rupes TA50 Mini Sander with Meguiar's Xtra Cut MF Discs in action!
  1. The #7 Rub Down Technique by Mike Phillips
    Last Post: 09-02-2021, 09:19 AM
  2. Mike Phillips PBL Paint and Surface Coating Application Technique
    Last Post: 06-01-2021, 08:28 AM
  3. Replies: 27
    Last Post: 04-01-2021, 01:14 PM
  4. Replies: 11
    Last Post: 02-14-2019, 02:29 PM
  5. RIDS - The Definition of RIDS and the story behind the term...
    Last Post: 12-12-2012, 08:57 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
