Results 1 to 6 of 6
    Hand Scrubbing versus Machine Scrubbing Tires - 1971 Charger R/T 440 Magnum
    I detailed this old 2-door Dodge as a part of using and shooting a video for some new products plus writing a few reviews. There's always,
    One more thing....
    The tires.
    The tires have been maintained with a good dressing but it's simply time to remove whatever is there and replace it so the sidewalls are clean and refreshed. I never hand scrub tires any longer but I thought I would refresh my memory as to what it's like and in the process of cleaning and dressing these tires I took a few pictures.
    And here's the deal - once you machine scrub tires - you'll never go back to hand scrubbing.
    This first tires is the back tire, I accidentally saved over the original showing the ENTIRE tire as I was cropping out and then saving smaller areas to show either dirt on the sidewall or scuffing?
    I present.... an old 2-door Dodge!
    Hand scrubbing works but machine scrubbing kicks tires!
  2. Thanks derass, Thomkirby thanked for this post
  3. #2
    Sep 2017
    35
    Re: Hand Scrubbing versus Machine Scrubbing Tires - 1971 Charger R/T 440 Magnum
    I still do it by hand. Its what im used too and get quick and wonderful results. Nice Charger.. He need a set of OEM tires to finish it off.
  4. #3
    Quote Originally Posted by TopBlissGT View Post
    I did it like this for years, then about 6 years ago, when I wanted to coat some 40" tall Toyo tires, I put 2 and 2 together and attached a Cyclo brush onto a Porter Cable Polisher and came up with machine scrubbing tires and have never looked back.
    The cordless PE14 works better and because its battery powered - no shock risk.
    Like the tires on this car...
    Original Paint Restoration - 1970 Bronze Metallic Corvette - Pinnacle Jeweling Wax- Porter Cable
  5. #4
    More....
    Old 2-door rag top Plymouth....
    Quick, simple fast and easy.
  6. #5
    Mar 2018
    Conroe, Texas
    477
    Question Mike,
    I bought both the 5-inch Heavy Duty Brush heads for the rotary/DA backing plate (velcro).
    Now I need to order a backing plate for the rotary and AG has the Lake Country 4-3/4 inch or Buff&Shine 5-inch in those smaller sizes.
    Will either of these fit those brush heads?
  7. #6
    Quote Originally Posted by Thomkirby View Post
    Question Mike,
    Good question. I know the Lake Country Backing Plate I share in this article works for sure,
    Quick and easy tire detailing - Use a water-based all-in-one rubber & vinyl cleaner/conditioners instead of tire dressings
    This backing plate,
    Rotary 4 ľ inch Flexible Backing Plate
    Sometime today I'll check on the B&S backing plate and get the size and part number that will work with this brush.
    Heavy-Duty DA Carpet Brush – Long Bristles
    I'm an equal opportunity exploiter when it comes to brands.
  8. Thanks Thomkirby thanked for this post
  1. Video Class: Tire Coatings - Machine Scrubbing Tires - BEFORE & AFTER Pictures
    Last Post: 06-04-2020, 03:58 PM
  2. Scrubbing Bubbles on leather???
    By CleanFlow in forum Auto Detailing 101
    Last Post: 10-03-2015, 03:31 PM
  3. would scrubbing to hard with car wash damage rim
    By Bill1234 in forum Auto Detailing 101
    Last Post: 05-09-2012, 06:12 PM
  4. Tires still brown after scrubbing...
    By rockford33 in forum Auto Detailing 101
    Last Post: 09-12-2011, 10:07 PM
