Re: Supa BEAST backing plate swap
Originally Posted by Dr Oldz
Mike or anyone who can verify for sure,
1 Do the backing plates come with the Allen style bolts? The old plate on my finisher has torx. I’d prefer the Allen style.(the CBeast comes with the updated BP and Allen bolts) I want to update my corded finisher.
2 Are both size backing plates in stock at AG the newer updated versions with the locking tabs?
Thank you
Jim
I'll be into the office after lunch to shoot the Live Broadcast video with Yancy and can check.
Bumpity bump!
Sorry, I forgot to walk out and look at the shelves....
BUT - See what Sizzle Chet posted here just yesterday, April 14th, 2020
3401 replacement backing plate - in stock soon?
Originally Posted by Sizzle Chest
Received my plates today! Yeah!
Or call Customer Care, I'm sure they can find the answer.
1-800-869-3011
I wish I had gotten one of these instead of my G9, way outta my price range though (literally 3x the price of a G9 up here )
Ah yes....
Canada....
Re: Supa BEAST and CBEAST Backing Plate Swap by Mike Phillips
Out of these pads, do you prefer one or the other cutting, polishing, or finishing pad over the other?
Yes. Whenever I can use foam and it makes sense, I prefer foam. Sometimes fiber makes more sense for speed and efficiency because fibers are a form of abrasive.
Fiber pads are like a coin. A coin has two sides.
1: One side of the Fiber Coin is it cuts faster because fibers are a form of abrasive.
2: The other side of the Fiber Coin is because fibers are a form of abrasive - they can leave a CUT in the paint when you've finished buffing. When using any brand or type of orbital polisher this is called micro-marring. When using a rotary polisher this is called holograms.
Here's something I wrote years ago,
Generally speaking, a foam pad will finish out nicer more consistently over a wide spectrum of paint systems -Mike Phillips
So if I can cut with a foam pad and get the defect removal results I'm looking for on any given project I'll choose foam. Sometimes I can finish with this same foam pad and sometimes I have to re-polish, depends on the paint. But if I end up having to do a 2-step process, by starting with foam the polishing will be faster and easier as it won't have the depth of cut that a fiber pad will leave if a fiber pad is used first.
The above is generalities as paint hardness and/or paint softness is the huge unknown variable.
Or as Jason Rose likes to say,
Topcoat hardness is the unknown variable.
Hope that helps...
Last Post: 08-24-2022, 05:02 AM
Last Post: 10-07-2021, 02:58 PM
Last Post: 02-16-2021, 01:00 PM
Last Post: 12-31-2020, 02:28 PM
By Heisenberg in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 10-21-2015, 10:23 AM
25 | 26 | 27 | 28 | 29 |
