Results 11 to 20 of 30
    Jul 2016
    3,328
    Re: Why I call the FLEX 3401 the BEAST! by Mike Phillips
    Do you typically compound a whole panel like the hood before buffing the compound off or is that for demonstration purposes Mike?
    Just wanted to add that the new millie polishes work fantastic with the flex
    Quote Originally Posted by fightnews View Post
    Depends on the project but in this instance it was for demonstration purposes.
    If I were doing a one-step production detail, for example detailing a daily driver using BLACKFIRE One Step, then "yes" I would tackle half of a hood at one time because the tool can flat out handle it.
    Just wanted to add that the new Millie polishes work fantastic with the flex
    I'll have to give the RUPES Mille compound and polishes a try with the FLEX. Makes sense.
  3. #13
    Jul 2015
    South Burlington, Vermont
    37
    How does the BEAST handle heat generation when doing such large/long sections? I know if I did the same section with my GG6 DA, it would likely lead to pad/plate melting failure. (which I've done before)
    Or is the key to use a LOT of product to keep friction at a minimum?
  4. #14
    Quote Originally Posted by royalkangaroo View Post
    No worse than any other tool and possibly better.
    Remember, heat is always an unwanted byproduct of the process.
    Using the product, as I say, heavy or wet, or using an ample amount of product can help reduce overall heat by reducing overall friction but when it comes to any orbital polisher, when you run any tool at high speed, the oscillating and rotating action plus TIME, plus PRESSURE results in heat.
    It's also a VIOLENT action at high speed and this violent action tends to be hard on pads first and then backing plates.
    I do go through pads and backing plates but never to the point where it's an issue.
    The best way to avoid losing pads is to switch to a clean, DRY pad often.
  5. #15
    Super Member Mike Hoekstra's Avatar
    May 2020
    Grand Forks, ND
    470
    I own a 3401 and an XFE 3" mini. I love them. The 3401 will just go and go, and well.... keep grinding as hard as you want. My Pixie shipped today too finally after being backordered! Whooohooooo!!!!!!
    Owner/Operator Auto Massage LLC - www.automassagellc.com
    Custom painter and commissioned artist - www.spikedairstudio.com
  6. Likes John U liked this post
  7. #16
  8. #17
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    659
    Quote Originally Posted by Spikey Mike View Post
    The Pixie is a great addition. Do you see Wes Rydell cruising the shows? I see him out in AZ during the winter months.... very meticulous with his cars.
  9. #18
    Super Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    2,243
    Beast is on my list....
    Tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
  10. #19
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by TMQ View Post
    Tom
    Get a 3401 NOW while you still can. I LOVE mine and while the new XCE is a great replacement, runs a tick smoother and is a lot quieter, it is a little slower overall. I use both now regularly but would miss not having a 3401. Call me silly but I may just buy yet another one before too long just to have it "in case" I need it.
    2023
  11. Thanks TMQ thanked for this post
    Likes JustJesus liked this post
  12. #20
    Mar 2015
    Germantown, Md
    2,243
    Geez....had to do it!
    Bought me a beast!
    Thanks for the push...
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  13. Likes TTQ B4U, JustJesus liked this post
  1. Replies: 2
    Last Post: 10-15-2020, 08:25 AM
  2. CBEAST Battery Life aka the FLEX Cordless 3401 by Mike Phillips
    Last Post: 07-26-2019, 07:46 AM
  3. FLEX 3401 or RUPES? - A question I get asked a lot! -Mike Phillips
    Last Post: 03-04-2019, 08:24 PM
  4. Book Review: How to use the Flex XC 3401 by Mike Phillips
    By Dr_Pain in forum Product Reviews
    Last Post: 11-30-2014, 10:51 AM
  5. Joined the Flex family- 3401 Thanks Mike Phillips, Smack, Tato
    By Justin at Final Inspection in forum Flex Polishers
    Last Post: 07-17-2014, 10:10 AM
