» Detailing Classes
Page 5 of 5 FirstFirst 12345
Results 41 to 43 of 43
  1. #41
    Oct 2019
    Gilbert, AZ
    Re: Coated under 15 minutes using PBL Surface Coating
    Quote Originally Posted by BSoares View Post
    CQuartz feels much different when Gliss is applied over it. The paint then feels slick and more hydrophobic. I don't know if you're willing to now put that on top due to how complicated it can be but next time you coat with CQuartz make sure to use Gliss as well.
    Interesting Bruno, is CQuartz grabby like I said without Gliss? I currently have Reload on top of it per CarPro's recommendation. I don't think I'd want to spend the money on Gliss at this point. If I was going to do anything I'd strip the Reload and apply PBL Surface Coating. My car budget it tapped out.
  2. #42
    Senior Member BSoares's Avatar
    Mar 2017
    Exton, PA
    1,154
    Quote Originally Posted by paulgyro View Post
    Yes, CQuartz is grabby w/o Gliss. That's why they released the topping coat, to fix that issue. It also adds a bit more gloss and water behavior.
    Once the car is coated and already had Reload on it, then it's too late for Gliss. There's a way to try and strip Reload but I'd guess at that point the durability of Gliss will be affected.
    Next time you do the entire process again, don't be scared of going with CQuartz but keep in mind Gliss would make the coating much nicer.
    Bruno Soares
  3. #43
    Senior Member Coatingsarecrack's Avatar
    Dec 2018
    1,531
    I like Cancoat on top of my CQUK3.0. Looks good and adds a little slickness if your into that
  4. Thanks paulgyro thanked for this post
    Likes paulgyro liked this post
  1. Replies: 0
    Last Post: 10-08-2016, 10:18 PM
  2. 3M Double Adhesive On Opti Coated Surface?
    By Marc08EX in forum Auto Detailing 101
    Last Post: 10-11-2014, 04:45 AM
  3. Replies: 2
    Last Post: 11-08-2013, 04:09 PM
  4. Replies: 7
    Last Post: 11-03-2013, 06:34 AM
Members who have read this thread: 148
» January 2020
293031 1 2 3 4
