» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Senior Member RTexasF's Avatar
    Jun 2006
    North TX
    2,519
    Re: From NEGLECTED to RESPECTED! 1985 Cougar Tunnel Hull Extreme Makeover at Autogeek
    My Sanger used a Casale V-Drive with 18% overdrive. Engine is a 402 BBC with small port closed chamber heads. Engine builder is Tim Briggs, means something in Oregon.
    Carbs were 660 Center Squirters and Tim reground the linkage to make them progressive like a Double Pumper instead of all 8 barrels dumping at once. Some of you will know what this means.
    Before modifying the linkage, when you put the pedal to the metal and all 8 barrels would dump at once, sometime the engine would backfire and it would throw a flame ball out the front of the scoop and past your ears.
    Prop was a 17" pitch 2-blade - each time the prop makes one rotation it would propel the boat forward 17" - or that was the hope or theory.
    It takes special talent to run a flat bottom V Drive at speed. Working both the throttle and the cavitation plate at the same time requires guts, serious coordination, and a "feel" for the boat. Mike I know you paid a dear price but I appreciate the fact that you still miss your Sanger.
    Rick....now in North Texas
  2. Likes Aaryn NZ, PaulMys liked this post
  3. #22
    Senior Member Belo's Avatar
    Jul 2014
    Rochester, NY
    426
    my dad has a boat, my buddy has a boat. everyone says don't buy a boat, use someone else, but this makes me want to find a discounted boat that needs some cosmetic tlc. Found one on craigslist even haha.
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
  4. #23
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    5,486
    Quote Originally Posted by Belo View Post
    my dad has a boat, my buddy has a boat. everyone says don't buy a boat, use someone else's
    This is correct.
    I worked on boats and on the water for almost 40 years. Don't do it. Lol
    BOAT- Bust Out Another Thousand.
    Definition of a boat: A huge hole in the water that you try to fill with cash.
  5. #24
    Jun 2009
    Stuart, Florida
    43,928
    More....
    Before I took off for the Texas Roadshow Detailing Class I was doing garage laundry and took this picture. This shows how many pads we used to do the correction and polishing work to the Cougar Tunnel Hull.
    Today I put the foam pads away. Have not washed the wool pads yet.
    I'm sharing this because from experience, I would say most people, most detailers included, don't know how many pads it takes to do this type of work. Here's a clue... it takes more than one pad.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  6. Likes JKDesign, SWETM liked this post
  1. The Cougar Tunnel Ram has arrived!
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-25-2019, 11:20 AM
  2. Boat Video Project - Restoring the Gel-coat on a 21' Cougar MTR Tunnel Hull
    By Mike Phillips in forum Sign up for Wednesday Night Projects
    Last Post: 05-23-2019, 09:53 PM
  3. Pictures: 1969 Oldsmobile 442 - Extreme Makeover! At Autogeek!
    By Mike Phillips in forum Pictures from Wednesday Night Projects
    Last Post: 07-07-2016, 08:54 AM
  4. 1985 GMC Rally Van - Extreme Makeover! With McKee's 37 - FLEX- RUPES - BOSS
    Last Post: 03-09-2016, 08:26 AM
Members who have read this thread: 104
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
