» Detailing Classes
Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 67
  1. #51
    Member
    Nov 2018
    ARIZONA
    47
    Re: Good rule of thumb when using an AIO - stick with foam polishing pads by Mike Phillips
    I think someone else asked it earlier, but what LC foam pad is ideal for an AIO? There are multiple different LC foam pads. Which LC 'model' of the foam pad should be utilized? the CCS? the Hybrid? the Flat pads?
    - Scott.
  2. #52
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    10,224
    Quote Originally Posted by PSYS View Post
    The Flat Foam Pads or the ThinPros. I personally stay away from the Hybrids and CCS Pads. Hybrids tend to be preferred by people who use the Flex Polisher, which is forced rotation. And the CCS pads are a bit archaic.
    I like to use the White Foam Polishing Pads for AIO’s. I like the Flat Foams for that duty.
  3. Likes PSYS liked this post
  4. #53
    Senior Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    719
    Agree with Eldorado2k’s response above. The best pad choice is partly determined by which dual action polisher you’ll be using for the job.
    You indicated you use a GG6. Stick with thin pads and you’ll experience less stalling when using this machine.
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
  5. Likes PSYS liked this post
  6. #54
    Member
    Nov 2018
    ARIZONA
    47
    Thanks fellas...
    - Scott.
  7. #55
    Senior Member Stevedotmil's Avatar
    Feb 2013
    Columbia, SC
    118
    I’ve had good results with HD Speed/GG6/GG Fast finishing 5.5 MF red pads. I just did a 1st gen Honda Ridgeline with black paint and it came out nicely. It’s a hunting/woods truck most of the time and he ended up telling his wife his hunting season was over unless he took her minivan because it looked so good.
    I can’t seem to get the pic to post in here. I can’t upload it or post the link method. I’m on the iPad.
    https://www.facebook.com/newfinishPDLLC/
    Steve Infante, New Finish Columbia 803-553-1782
    Columbia, SC / IG:@newfinishcolumbia
  8. #56
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    3,950
    Quote Originally Posted by Dr Oldz View Post
    I have learned from experience than a one step is an improvement and not perfection.
    I feel, generally speaking, that most people prefer glossy with some swirls and RIDS Over a dullish looking finish.
    ^^ this and I've configured my packages and presentation to that point.
    • Basic clean and protect- is just what you described. It's NOT a correction but rather a perfectly executed cleaning and refining type polish that will reduce the appearance of swirls through ramping up the gloss but it's not a correction.
    • Premium Enhancement Polish - is a minor correction and involves either a polish and sealant (AIO) or a polish and a seasonal coating like CanCoat. I offer the latter as a small upgrade charge. Aimed at 50% reduction/correction but upwards of 75%+ is common and easily achieved depending on what I get to work with finish wise.
    • Elite Enhancement Correction - is a true two-step correction process of compound and polish followed by a sealant or a coating; again at an upgrade charge for the latter. Aimed at 75% correction which is common but upwards of 90%+ is often achieved, again, depending on what the customer comes in with
    • Signature Level Perfection is what I call my 100% corrective process. As the name notes, it's a true multi-step full correction package.
    No surprise that the first two packages are my most popular. I think the most important aspect is presenting them to the customer based on what they come in with and what they desire to leave with. I've had customers come in thinking a "detail" IS a Full Correction. That's fine as it may be at some shops, but with me, I offer pretty cost effective choices. I've also had the opposite that a basic clean and protect costs more than what customers are looking to pay. Some still think a detail is a wash and hand wax and that's it.
  9. #57
    Nov 2009
    Pasadena, CA
    12,443
    Quote Originally Posted by TTQ B4U View Post
    Exactly!!! Including interior as well! What are they smoking????????????
    '03 Corvette Z06
  10. #58
    Jul 2017
    Casper, WY
    641
    Hitting that crack you
  11. #59
    Jun 2009
    Stuart, Florida
    42,556
    Just to chime in...
    Great comments throughout the thread. The Big Picture I'm trying to share is be careful about using foam cutting pads as your default go-to pad when using any AIO and that is because sometimes the pad ALL BY ITSELF can leave PAD HAZE. Pad haze is micro-marring. It's where the pad itself is scratching the paint.
    If you sell a one step process to a customer and use a foam cutting pad only to find out after doing the one step application of the AIO that now there is micro-marring throughout the paint - NOW you have to redo the entire car to remove the micro-marring and now you're no longer making a profit because now you're doing a two step process for a one step price.
    For all the people that attended my Roadshow Class in Roswell, Georgia - they saw this first hand. Until you see it first hand you may doubt what I'm trying to share with this thread. But if you do enough one-step details using foam cutting pads sooner or later it's going to bite you in the behind and you're going to remember this article and think,
    He was right
    So anytime you're doing one-step detail jobs TRY to stick with foam polishing pads and START the business deal with the customer by setting their expectations REAL WORLD.
    If the customer wants 100% correction that's fine. Make them pay for it. That's a 2-step or 3-step process not your 1-step process.
    I see expertise the FB Group world all the time sharing how they use foam cutting pads with AIO's to maximize correction results and it's true, you will get more correction using an AIO with a foam CUTTING pad but you might also get pad haze throughout the entire finish. So be careful where you get your expert information.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  12. Likes jolo liked this post
  13. #60
    Senior Member xabo's Avatar
    Mar 2013
    D.C.
    114
    Can a AIO be used with a rotary?
  1. How to use a foam gun by Mike Phillips
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 10-05-2018, 05:16 PM
  2. Pontoon Polishing - Attn. Mike Phillips
    By hammargren in forum Boat & Marine Craft Detailing
    Last Post: 05-01-2018, 10:12 AM
  3. Marketing yourself with good before and after pictures by Mike Phillips
    Last Post: 05-16-2017, 07:19 AM
  4. Replies: 8
    Last Post: 05-02-2017, 06:34 AM
  5. The Rule of Thumb
    By Mike Phillips in forum Wet-Sanding, Cutting & Buffing
    Last Post: 05-17-2012, 07:58 AM
Members who have read this thread: 179
» May 2019
