Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
  1. #31
    Super Member theamcguy's Avatar
    Dec 2007
    Fayetteville, NC
    260
    Re: My Pad Prediction - Smaller Wool Cutting Pads for smaller rotary polishers
    Mike whatever happened to this project? Did the pads ever get developed?
    Bill Strobel
    Owner Independent Towing & Repair
    Fayetteville, NC
    Do It Right or Don't Do It At All
  2. #32
    Quote Originally Posted by theamcguy View Post
    Sad to say but "not yet".
    The problem is due to the efficiency of orbitals - I don't do a lot of rotary work so it was difficult to spend lots of time using wool pads.
    The good news is RUPES released their wool pads and they were exactly what I described in this prediction. Maybe they were lurking and doing opposition research?
    I like the diameter size - it works great with compact rotary buffers including CORDLESS rotary buffers
    I like the pile or fiber length - too short and the pad is too hard - too long and it's floppy and you lose precision at the edge of the pad.
    I like the fill ratio - too dense and the pad is too hard and also too difficult to clean.
    Here's a visual indicator as to what I think of the new RUPES twisted wool pads.
    It doesn't get any harder than buffing out your sanding marks on a large boat. It's grunt work. Look at what we used,
    Time to buff...
    I know some guys would have sanded with #3000 and then started buffing. Heck some guys would have started with #2000 or skipped the sanding step altogether. My goal was to make Royce's boat look as good as possible while saving gelcoat and also saving ourselves. This was my way, everyone can find whatever way works for you and meets your criteria as well as your expectations for quality of finish results.
    The cordless FLEX PE14 with a 6.5" wool pad has plenty enough brute strength to power through this job. And no cords.
    Review: 3D Ceramic Coating on a Marine Gelcoat Boat
    But like I said at the end of post #6 here,
    Rupes 15 III vs. Gear Driven DA’s
  3. #33
    Dec 2007
    Fayetteville, NC
    260
    Great Mike, I just checked the store for the Rupes Twisted Wool Pads and it looks like 5" is as small as they go. Nice size better than 6 1/2 - 7" for a cordless. Keep us up to date on any new developments and Thank you for your time.
    Bill Strobel
    Fayetteville, NC
  1. Advice On Smaller Pads
    By BigHead in forum Wool & Foam Buffing Pads
    Last Post: 03-04-2015, 09:01 AM
  2. which smaller pads to go with 5.5" on a PC?
    By flyinion in forum Auto Detailing 101
    Last Post: 07-19-2012, 08:28 AM
  3. Smaller pads, ditch the counterweight?
    By 05RLS2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-26-2011, 11:29 PM
  4. So You Want to Use Smaller Pads with your Flex ???
    By ScottB in forum New Car Care Products
    Last Post: 05-12-2009, 08:33 AM
  5. New Smaller Rotary Backing Plate
    Last Post: 03-11-2009, 01:18 PM
