Results 11 to 20 of 25
    Mar 2014
    Re: The Air Test - Using NON RUPES pads on RUPES Polishers
    Great job on the book Mike. I received mine the other day and have read an been studying it before I decide on rupes or flex. Leaning towards the rupes and it's system.
    May 2013
    Spring, Tx
    125
    ha ha....I JUST got my Rupes 15 Mark II from a fellow member that sold it to me. I have a 2002 Camry that I painted a few years ago, and needless to say, it's in dire need of another paint job. The paint was faded and I basically don't care what the paint looks like, as it'll be weathered again an a month or so. I'm not a painter by any means, and I only paid $120 to do it myself....and it shows.
    Anyway, not wanting to ruin my pads that came with the polisher, I used some cheap a$$ harbor freight pads because they are basically trash anyway. When i started polishing, i felt a lot of vibration. I was like....holy crap, this polisher sucks. No wonder why he sold it. I went to my Flex 3401 and it was like night and day...way smoother. Ok...something is wrong here. I went back to the Rupes, and again...a lot of vibration. So, i decided to sacrifice the worst pad that I had gotten in the package deal. I picked a yellow pad, sprayed some pad conditioner on it, slapped some HD SPEED on the pad, and went to town.
    HOLY MOLY !!! Smooth action. No vibration. Like butter on a hot roll. Like when a sniper hits his target, sees the "Pink Mist", and pulls back the bolt to load another bullet. The smoothness of the action, the shell being ejected, the firing pin being reset, the next bullet being loaded into the firing chamber....the sensation of becoming ONE with his tool.
    That was my experience with my Rupes in less than 5 minutes.
    Now, i need to just get my method down on using this polisher. Using my method that i learned on my Flex is not going to work. They are completely different machines.
    The Flex 3401= Rambo with an M-60. When you see him, you know he's gonna f**k s**t up !!
    Rupes= James Bond. Classy, dignified, a real ladies man. Cool under pressure, but when he kills, he does it in a 3 piece Tux, and never breaks a sweat.
  3. #13
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    1,990
    Rupes yellow pad is always such a joy to use...so smooth and effective.
  4. #14
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,011
    Quote Originally Posted by Levithan9 View Post
    Love the analogies!
  5. #15
    So just to clarify for me and anyone else....
    When you used the cheap Harbor Freight foam buffing pads on the RUPES BigFoot 15 Mark II polisher the tool vibrated like crazy.
    Then when you used a RUPES YELLOW foam buffing pad on the RUPES BigFoot 15 Mark II polisher it was perfectly smooth.
    Correct?
  6. #16
    May 2013
    Spring, Tx
    125
    That is correct, Mike.
    I'm starting to view the Rupes polisher as a WHOLE system. Kinda like Apple. Got an iPhone? Your gonna use iMessage. Gor a Rupes polisher? Your gonna use Rupes pads.
    I see my Flex as an Android based system....i can use anything. It might work, it might not. Rupes has just taken out the guess work on what WILL work.
  7. Likes Jeremy5431 liked this post
  8. #17
    Another good analogy.
  9. #18
    Re: The Air Test - Using NON RUPES pads on RUPES Polishers by Mike Phillips
    ***update***
    This article referenced here,
    Rupes LHR15 Mark II, for cutting?
  10. #19
    Jul 2016
    3,328
    Force pads work good on the duetto
  11. #20
    Nov 2009
    Pasadena, CA
    12,615
    Initially, I always thought the system approach might be a gimmick to only buy their products. However, I've changed my mind about that with Rupes. The Rupes pads definitely run smoothest on their polishers. It's a TUNED system. I haven't gone as far to only use with Rupes polishes, though. Rupes Polisher, Rupes correct backing plate size, and Rupes pads....yes.
    '03 Corvette Z06
  1. Test drive - NEW RUPES Mille and Rotary Buffer by Mike Phillips
    Last Post: 07-15-2021, 08:58 AM
  2. FLEX 3401 or RUPES? - A question I get asked a lot! -Mike Phillips
    Last Post: 03-04-2019, 08:24 PM
  3. New Rupes Duetto and Rupes Mini Polishers vs Prototypes
    Last Post: 11-13-2013, 08:04 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
