Re: Quick & Easy Emblem Removal
I bet you have one clean Honda Si Nick. The badge looks much better off the car indeed. I had trouble with fishing line in the past on emblem removals. I now use a bondo spreader in place of the fishing line. It has worked great for me.
Thanks for another great write up.
Jeff
2012 Toyota Tundra 5.7L 4x4
McKee's 37 Product Support
Originally Posted by addysdaddy
So what happens if you want to put the badging back on - suggestions?
I would spend the money on a new badge (already comes with adhesive perfectly matched to emblem) if I wanted to put it back on.
Another option, like someone else, is to simply pick up some 3M double sided tape and cut it to fit.
Originally Posted by SR99
If you spray some adhesive dissolver on before you begin sawing (so that you're sawing with adhesive remover mixed in there as well) the sawing can be easier.
I would personally avoid this technique because I don't like the thought of a harsh solvent (adhesive remover) dwelling on my paint for more than a few seconds.
And as a footnote for future reference on a different application of the same concept, this same process can be used to remove a big bathroom mirror from the wall without breaking it. The mirror is usually attached with a blob of adhesive in each corner. Take your fishing line, tie a steel washer on the end, drop the washer behind the mirror from the top, then use a magnet to pull the washer (and the fishing line) out the side of the mirror so you can "saw" away the blob of adhesive. Pour some sort of adhesive dissolver behind the mirror, from the top, to aid in the sawing. I think I actually found that a twisted-strand steel wire (the kind used for hanging pictures) worked best since it has some "teeth" to it.
Good to know!
I'd like to think that I have the cleanest Si in the state of Florida.
Another great tip...keep 'em coming!
Civic Si "Rain Forest" Road Beauty Shots
Originally Posted by parshooter
If you don't have any fishing line, you can use dental floss also.
I use a plastic kitchen spatula. Just gently wedge it under the emblem and apply pressure as if you're trying to pull it off.
Hit it with your hairdryer and the same time. In about 60 seconds the emblem and 90% + of the glue will come off cleanly. No marks scratches or issues. Been doing it this way for years.
Sent from my SAMSUNG-SM-N920A using Tapatalk
By frankprozzoly in forum Auto Detailing 101
Last Post: 06-30-2014, 09:37 AM
Last Post: 05-10-2012, 10:45 PM
Last Post: 05-17-2011, 09:13 PM
By john b in forum Auto Detailing 101
Last Post: 11-22-2010, 08:38 AM
