Re: Building pressure washer
yea but remember, direct drive may give you problems pulling from a tank. you may have to prime it. Cats are expensive to rebuild. I have one cat that we use and when it craps out we are replacing it. Everything else I have are general pump or udors. We run them hard as well. Theyre all bypassed back to the tanks and have atleast 1 inch feeder lines running to them. They last a while if you do it right.
Thanks RonG do you have any photos?
I like this KARCHER SKID UNIT HD with 12 volt pump and tank have to get a price. HD 2.5/27 P St | Kärcher North America
[ame=http://www.youtube.com/watch?v=k_CUkXobZ0Q]5.5hp Pressure Washer Pump which sucks water - YouTube[/video]
Is it this simple or more to building, I can get a HONDA ENGINE and A PUMP just bolt it up and it should work?
Bought this today (Black Max 2,800 PSI Gasoline Pressure Washer - Powered by Honda - Sam's Club)
since it claims self priming, until I can purchase a horizon unit or build (bolt a pump onto a engine) or buy small KRANZLE K1622 1600 PSI - Electric Cold Water Pressure Washer
and more powerful generator than the HONDA EU 2000i I purchased earlier this year.
Yea or you could do a gear box as well. There's a guy here in Louisville ky, Russ Johnson at south side equipment. He can get you the best fit. Gear box would work better for being compact.
Russ os GREAT. Southside is one of the best suppliers IMO, and Russ is extremely helpful. I suggest you give him a call and he'll set you right up.
I also recommend the belt drive -- it will not only draw water faster, but it will last 3 times longer, too.
You can get a good 4 GPM beltdrive for around $1000 online.
By CaveRacing in forum Auto Detailing Tools and Accessories
Last Post: 04-27-2018, 08:02 AM
By josher in forum Auto Detailing 101
Last Post: 12-13-2017, 08:25 AM
By ndsports in forum Auto and Garage Accessories
Last Post: 02-04-2017, 03:09 PM
By ski2 in forum Hot topics & Frequently Asked Questions
Last Post: 02-26-2014, 02:19 PM
By bmwgeek in forum Auto Detailing Tools and Accessories
Last Post: 10-28-2011, 03:11 PM
25 | 26 | 27 | 28 | 29 |
