Results 21 to 30 of 40
  1. #21
    Re: The Aggressiveness Order of SMAT Products - This might surprise you!
    Quote Originally Posted by M64 View Post
    Wow that was a fast reply!
    Thank you!
    I'm kind of a speed typist, plus I use tools that prevent carpal tunnel...
    Go through my posting history for just today...
  2. Likes RiverDog liked this post
  3. #22
    Junior Member M64's Avatar
    May 2012
    South Africa
    55
    Those things are genius! another great use for a microfiber bonnet!
    Marc
    Performance Detail
    www.facebook.com/performancedetail1
  4. #23
    Super Member shoeless89's Avatar
    Jul 2010
    Union, KY
    1,985
    Thats a crazy setup Mike!
    Rule 62: Don't take yourself to d*mn seriously
    Cincinnati, OH
    Shawn
  5. #24
    Regular Member mhphoto's Avatar
    Jun 2012
    157
    ColorX is a DAT product so it doesn't fall into "this" line-up. But overall aggressiveness relative to the other products pictured I would put it between PRC and SwirlX.
    *slaps forehead*
    That's makes sense.
  6. #25
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Where does D300 stand in the line up?
  7. #26
    Aug 2011
    The "OC"
    895
    I'm gonna venture and say between M95 and Ultimate Compound, but definitely between M105 and Ulitmate Compound.
    Also assuming D300 with MF pad as it was designed for.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
  8. #27
    Jan 2007
    14,094
    Quote Originally Posted by SonOfOC View Post
    Have you used D300 with an orange LC pad?
  9. #28
    Aug 2011
    The "OC"
    895
    I have used D300 with Orange and even mixed D300+m105 with orange.
    In the end, D300 with MF works so well that it's my go to combo for cutting. The MF cuts better than the Orange, and finishes down to levels that the orange foam can only dream about.
    I use MF for cutting exclusively now, but still use foam for finishing.
  10. #29
    Super Member Capa1970's Avatar
    May 2011
    Jenks, Oklahoma
    494
    mm
  11. #30
    Mar 2013
    Mike,
    I read in one of your other threads that you believed Swirl-X was going to be discontinued. Is that still the case? Also, the new Water Spot Remover has micro abrasives in it, where would this fall in the agressiveness chart? Thanks for the help!
  1. Replies: 39
    Last Post: 07-11-2020, 09:18 AM
  2. Replies: 15
    Last Post: 04-28-2017, 07:37 AM
  3. Got my order, got my surprise gift
    By runrun411 in forum Off-Topic
    Last Post: 12-08-2015, 11:45 AM
  4. Order Of Aggressiveness?
    By amnbcn in forum Wool & Foam Buffing Pads
    Last Post: 12-20-2012, 09:02 AM
  5. Dat or Smat products
    By Schiffdog in forum Ask your detailing questions!
    Last Post: 04-21-2012, 09:22 AM
