Product Suggestions for Exterior Trim & Tires
So I am looking for the best product that will cover both Tires and Exterior trim. Something that has longevity especially on the tires (using Megs Endurance Gel on it now).
I narrowed down the list to Ultima TTGP and Carpro PERL. Was also looking at the Wolfgang Exterior Trim product but it is not in contention as much as the TTGP & PERL.
I am looking for a product that is versatile and will cover both the tires and the exterior trim equally good .
Suggestions appreciated.
Re: Product Suggestions for Exterior Trim & Tires
Some products are better on rubber and some are better on plastic trim.
I am looking for something that will cover both grounds on the exterior. PERL & TTGP both seem to fit the description.
Not worried about inside plastic &vinyl. Just exterior.
Perl is good..UTTG has been changed and some don't like it, compared to the old formula. Like I said, IMO there are better products, but for individual uses.
If you are looking for something with great longevity, and only want to buy one product.....then I would personally recommend Ultima Tire & Trim Guard Plus.
Remember......proper preparation is key before application.
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
www.Carolinasfinestdetailing.me
Yeah I am looking for one product that will take care exterior plastic trim as well as good on the tires. PERL & TTGP were the ones I was considering. PERL says it can be used both inside & outside ( using different dilution ratios) but I am not too concerned about the inside as I have 303 and the Ultima IGP for the interiors. I do want something that will cover ground on exteriors and tires.
So what is proper prep to use TTGP? Just clean surfaces on the trim and clean tires and wheels before applying on tires?
i love PERL, 1:1 on tires and trim though you can use it full strength...
I am actually moving in the other direction. Tuff Shine Clear Coat beats out PERL on tires very easily.
TUF SHINE Tire Clearcoat, tuf shine tire dressing, permanent tire shine, permanent tire sealant
Originally Posted by pro 4x
Blackfire .perl won't last and wets is tacky and a dust magnet you can't go wrong with this product.The draw back as far as tires is once you apply your first application you can't stack to intensify the sheen.If you like your tires matted but treated then this product is for you.
By jrs1418 in forum Auto Detailing 101
Last Post: 12-16-2013, 01:50 PM
By Meticulous-Detail in forum Auto Detailing 101
Last Post: 11-09-2013, 11:35 PM
By Brad33 in forum Auto Detailing 101
Last Post: 09-06-2012, 07:19 PM
By Flannigan in forum Product Reviews
Last Post: 07-13-2011, 06:38 AM
By carguy in forum Auto Detailing 101
Last Post: 10-30-2007, 07:47 AM
