Re: Ceramiclear Paints - Be Careful
Originally Posted by 07 z-oh-6
Vette's don't have cerimiclear, do they? This is horrible news for a detailers!
You are always spot on buddy. You can add Ford to that list too. I used 3M UltraFine on the Audi and Ultima Paint Prep on the Ford before coating them. I just lucked up because I didnt know this til now!
I believe to date on Maybach, Mercedes, and BMW use the ceramiclear paint. Likely due to the cost, and supposedly only on their high line models. Any other models ??
Thanks for the post Mike. Will most definitely be helpful information.
Luxury Mobile Auto Detailing
Pensacola & Orlando
407.625.1480
I was having an issue with ceramic clear coat on a family members black e350. It ended up taking twice as long as I had expected, I ran out of time because they needed the car and had to skip the very last polishing step so it still has some very very light swirls that I'm going to correct later this week. All I can say is I do not ever want to work on ceramic clear again! It was an ordeal to say the least!
Mike..as always..thanks for the heads up..this is info I did not know...nor did others I am sure. It is always a comfort knowing you will be in our corner.
I did a little looking up - at least for some manufacturers, to check if the car has Ceramiclear, check the car's paint code - Ceramiclear paint has a "C" either before or after the three-digit paint code.
You're always spot on, bud!!
Yea, be careful with the Audi!!
Excellent info!!
Geez sounds like a nightmare. Why don't they just use regular clear, but apply it 4 times thicker than they currently do?
Oh my god, I wonder if my 2011 mercedes GL450 has the ceramiclear on it. It is black and this is the first car I am going to detail.
Maybe I'm missing the point here--is the point not to remove the "ceramic" portion of the clear because then you've removed the whole point of putting it on the car? Or is the point that after you've removed it that the remaining clear is horrendously soft? I don't see how the "underneath" part could be any harder to correct than Ceramiclear unless it's "sticky" or horrendously soft like that BMW jet black.
By jwgreen6 in forum Auto Detailing 101
Last Post: 08-28-2013, 11:47 AM
By hondacare in forum Auto Detailing 101
Last Post: 07-23-2012, 08:47 AM
Last Post: 05-01-2012, 08:47 AM
By FloridaNative in forum Off-Topic
Last Post: 07-08-2006, 12:03 PM
Last Post: 05-25-2006, 07:30 PM
