Results 11 to 20 of 21
    Feb 2012
    Under the flightpath of ORD 22R
    102
    Re: PC Modification For Use Without The Handle
    Thank you for the info & making it a sticky.
    I never thought of doing this on my 1st PC7424.
    On the new 7424XP, I went into the motorcycle parts drawer and pulled out some M8-1.25 black AL faring screws, cut them to length. I found the 5/16" washer fit in the recess better, so I have mix and match SAE & Metric.
    The 7424XP hood did not rattle around as much as the old 7424 I was using ( liberated from the shop to be used on vehicles a decade ago ). This is with very little hours on it. Could be the hood is attached better, or could be time would have turned it just the same. Either way I am covered.
    Thanks again for the info !
    Optimum Guru Chris Thomas's Avatar
    Dec 2007
    Middle Tennessee
    1,824
    My Flex came with plastic flat head screws that worked perfect for this on my PC. They were just there for shipping I suppose and were not to be used after installing the handle.
  3. #13
    Dec 2011
    weird... i can't take that black cover off my pc7424xp no matter what i do - yes, i cannot take it off...
  4. #14
    Dec 2011
    338
    I'd like to find some plastic screws for my PC, that hex head just looks way too gnarly lol
  5. #15
    Aug 2010
    Fairmont, MN
    3,044
    Quote Originally Posted by Stang Man View Post
    Check out your local hardware store. I've seen nylon (black and white) screws in SAE and metric. An 'Allen' cap screw looks good as well.
    Just be sure of your thread size. The PC comes in two flavors-SAE & metric.
    Bill
  6. #16
    Jun 2009
    Stuart, Florida
    39,365
    Quote Originally Posted by spyghost View Post
    Pry it off using a flat head screwdriver.
    IDA Board Member
    CD-SV, RT
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  7. #17
    Member
    Mar 2013
    I just went out to Home Depot for this screw and thought I would post more info so it would make it easy for those that might have trouble finding it. Here is a direct link to their website as well as pictures of the package for the screw. I was able to match the washer for the cap screw with those that they had in the bin....only .17 cents.
    If your still having trouble finding it in the store, grab a store employee and give him the Store SKU # 574324. They should then be able to take you right to it once they punch it into their system.
    The link to their website for the Cap Screw:
    Crown Bolt Plain Steel M8-1.25 x 16mm Socket Cap Screws-82688 at The Home Depot
  8. #18
    Senior Member zmanjohn's Avatar
    Mar 2013
    Clemmons, NC
    318
    If you do not like the look ot a screw head sticking out, you could also easily use a Button Head Cap Screw, I know they sell those at Home Depot also and they have a much more rounded head than the SHCS as shown in the previous pictures. Has a much lower head and less likely to scratch or catch any surfaces. You can also get either with a nylock thread locaker which will not allow screw to vibrate out.
    I hope this helps everyone.
    Attached Thumbnails Attached Thumbnails PC Modification For Use Without The Handle-button-head-cap-screw-jpg   PC Modification For Use Without The Handle-button-head-cap-screw-nylock-jpg
  9. #19
    Senior Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,276
    I have these:
  10. #20
    Senior Member erichaley's Avatar
    Apr 2013
    Lincoln, NE
    844
    Quote Originally Posted by Chris@Optimum View Post
    I also used the plasic screws that came with my FLEX 3401 VRG, they fit perfectly!!
  1. My Flex 3401 Modification
    By richy in forum Flex Polishers
    Last Post: 07-29-2015, 12:36 PM
  2. Website modification please
    By cobalt9123 in forum Customer Comments
    Last Post: 03-25-2011, 12:09 PM
  3. Handle? Or No Handle? - Using DA Polishers Without the Handle
    By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 01-16-2011, 11:24 AM
  4. DA Polisher: Stick Handle - Hoop Handle - Or no handle at all?
    Last Post: 12-04-2010, 07:14 PM
  5. Rotary Buffer- Stick Handle - Hoop Handle - Or no handle at all
    By Mike Phillips in forum Rotary Buffers
    Last Post: 09-24-2009, 07:51 PM
