» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    7,387
    Re: How To: GYEON quartz Q Trim
    You guys are in that other thread talking about money.... Meanwhile this is a job I’m no doubt doing for free. It’s my little brother cmon.lol.
    I already washed and sealed the paint. That 1st wash went ok but the drying of the virgin black paint with no lsp was PITA! Using the Big Blue felt like trying to dry the truck with a big plush blanket! Lol. I was like I better not be instilling swirls right now!lol. I made it through unscathed.
    Hey, blood is different. Unless you F it up........... :P
  2. Likes Eldorado2k liked this post
  3. #12
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    4,577
    Thanks for the reminder Jeff. I ordered some up yesterday to coat the trim on my wife's car and then mine later this summer once I re-do it all. Looking forward to using it.
  4. #13
    Member Jeff at Gyeon's Avatar
    Aug 2016
    Denver, Colorado
    81
    Quote Originally Posted by rlmccarty2000 View Post
    Can you apply Gyeon Trim over Solution Finish? Solution Finish is great on badly faded trim, but Gyeon Trim would lock in the shine and make it water resistant.
    No you would not want to be applying TRIM over Solution Finish. We want a pure bond between the coating in the plastics with no other product in between.
  5. Thanks rlmccarty2000 thanked for this post
  6. #14
    Jan 2019
    Quote Originally Posted by Jeff at Gyeon View Post
    Bringing this thread back to life...
    Jeff
    I can assume you would suggest using PREP in order to prep the trim for....TRIM. See what I did there? ....However, if you have a trim that might need a little boost/restoration, but would still like to use TRIM as a coating for extended durability, what product(s) would you suggest to use prior to applying TRIM? I ask because you didn't seem too keen on using Solution Finish prior to application, but i'm not sure if there are alternatives that would fit the bill.
    Thanks in advance.
  7. #15
    Jan 2016
    Central Ohio
    4,577
    Quote Originally Posted by Fenwayfan77 View Post
    Jeff
    I can assume you would suggest using PREP in order to prep the trim for....TRIM. See what I did there? ....However, if you have a trim that might need a little boost/restoration, but would still like to use TRIM as a coating for extended durability, what product(s) would you suggest to use prior to applying TRIM? I ask because you didn't seem to keen on using Solution Finish prior to application, but i'm not sure if there are alternatives that would fit the bill.
    Thanks in advance.
    I have used Solution Finish to restore trim that Q2 Trim just wouldn't darken up on its own. The key I found was to wait 1-2 months after SF application. I simply had my customer come back and do it 6-8 weeks after. Worked great and is holding up fine.
  8. Thanks Fenwayfan77 thanked for this post
    Likes Fenwayfan77, The Guz, DETAILROOKIE liked this post
  1. How To: Protect Your Wheels with GYEON quartz Q2 Rim
    By Jeff at Gyeon in forum GYEON Car Care Products
    Last Post: 03-08-2018, 01:00 PM
  2. Review: Gyeon Trim
    By kevincwelch in forum Product Reviews
    Last Post: 12-01-2017, 07:28 PM
  3. Video: How to take care of your automotive plastic trim - Gyeon Trim Care
    Last Post: 05-01-2017, 11:21 AM
  4. GYEON Quartz Q2M WetCoat: Instant Water Beading in a Bottle
    By Jeff at Gyeon in forum New Car Care Products
    Last Post: 03-13-2017, 03:57 PM
  5. NEW RELEASE: GYEON Quartz Q2 Matte Paint Coating
    Last Post: 02-06-2017, 11:00 AM
Members who have read this thread: 8
» September 2020
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
