» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Senior Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    1,781
    Re: Syncro 50ml Mohs vs 30ml - How much to use?
    Quote Originally Posted by ptcary View Post
    Back again, planning to do another Syncro kit, and want to try Gyeon compound, but want to ask if I can go from compound straight to primer, or is polish necessary in between, is this truly a 3 step process, or choose between primer and polish?
    After ~7 months the other cars with Synco and Mohs/Booster are still fantastic. Syncro seems better to me.
    No law will stop you from going from compound to primer as some compounds like Menz 400 can look LSP ready. If you want “all the gloss” a followup with a polish is probably required. Do a test spot with only a compound and then one with a compound and polish to see if you see a difference.
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    5,990
    This is fine. Primer is one notch below on the Gyeon cut scale compared to their polish.
  3. #13
    Member Jeff at Gyeon's Avatar
    Aug 2016
    Denver, Colorado
    70
    That will heavily depend on the level of marring caused by Compound that we are asking Primer to remove.Compound is a great mid range polish that will finish down nicely on certain paints and not at all on others. The pad, machine, and technique will have a lot to do with this as well. Primer does have less "cut" than Polish by design, so I would try it. If you get to the desired finish with Compound and Primer then awesome, but there is no way to know unless you work the paint with a few different combinations.
  4. Likes The Guz liked this post
  5. #14
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    3,940
    You can go from their compound directly to their Primer. Obviously do a test spot. Like CarPro Essence, Primer does do light correction work (not as much as a straight polish but....) when paired with a good pad/polisher. I run it with the Rupes Mille and their Yellow Mille Pads.
  6. #15
    Sep 2014
    Me again! Thanks for all the advice, you guys are great! So I finally got around to decon, autoscrub, compounding and polishing and am ready to do Syncro this weekend. Another question for you guys, if it rains outside the humidity will be high even though the temperature is supposed to be near 70.
    How bad does humidity effect both Mohs and Skin? Should I just plan for reduced time and pretty much an immediate wipe off for each? Or should I just wait for better weather out since this is not my daily driver.
  1. 2015 Impala with Gyeon Syncro (MOHS + Skin)
    By The Guz in forum Show N' Shine
    Last Post: 01-02-2019, 09:23 PM
  2. Thoughts on Geyon Pure vs Mohs & Syncro
    By TTQ B4U in forum GYEON Car Care Products
    Last Post: 05-04-2018, 04:58 PM
  3. Coatings....30ml/50ml...where's the line?
    By JCDetails in forum Auto Detailing 101
    Last Post: 02-05-2018, 05:24 PM
  4. AG Staff,Where's the 50ML of CQuartz?
    By IID in forum Customer Comments
    Last Post: 06-25-2011, 11:43 AM
  5. CQuartz 50ml bottle's ?
    By IID in forum New Car Care Products
    Last Post: 05-07-2011, 02:59 PM
Members who have read this thread: 33
» May 2019
