Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Sep 2020
    Eastern PA
    419
    Re: Griots G9 worth it? advice please
    5" pads are cheaper as well so the 5" backing plate will eventually pay for itself.
    Aug 2015
    Andover, MN
    1,217
    I can chime in having had a first and third gen GG6 (the predecessors to the G9) as well as a G9 (and G8, but I'll stay on topic).
    I'm gonna go the other way a bit here and say that a 5" plate on the G9 isn't the only way to use it.
    I feel like the recommendation to go straight to a 5" backing plate and thin pads goes back to the previous generation machines (both Griot's and Porter Cable). The 8mm stroke probably didn't come into play as much, but the lower power of previous machines definitely played into the thin pads being needed to keep pad rotation up.
    What I've found with my G9 is that with the extra power as well as the digital speed controller they use, a thin 5" pad isn't mandatory for good results. To the contrary, I've been finding there are times it's actually easier to keep the pad spinning with a thick 6.5" pad - namely tighter body contours like on the hood/front fender area of my wife's Q5 or curved surfaces like on more conventional fender profiles.
    If you go the 5" route (which I do honestly recommend having on hand as well - you can never have too many pads, and it's nice to have the flexibility of options!), definitely stick with the Griot's 5" backing plate made specifically for the G9 - the backing plate is designed into the cooling system for the machine.
    I'm just a hobbyist, but this has been my experience. If Sizzle runs a 5" plate, I'm inclined to spend more time working with my 5" pads next time I get a chance to run my machine, as he's got waaaaaay more hours behind a polisher than I do!
    For pads, I use the Griot's stuff for simplicity's sake - Mainly Orange (both standard thickness and BOSS thins). I've also used their BOSS microfiber and Fast Finishing microfiber pads. I've got hard Audi paint, so I haven't used my yellow pads much. Recently picked up a couple white Fast Correcting pads but haven't had a chance to use them yet.
    From what I gather from what I've read, the Orange Griot's pads tend to be a little on the softer side if you're looking for a cutting pad, so depending on what your Camaro's paint is like you can decide if they sound like a good match or not. I'm not familiar with other brand pads so I can't make any recommendations there. I'm also not familiar with the Menz polishes, I use the BOSS creams.
  3. Likes PaulMys liked this post
  4. #13
    Jun 2019
    355
    Quote Originally Posted by oneheadlite View Post
    I haven't tested it or anything but i personally "think" the orange BOSS pad as more cut then both lake country's SDO orange and rupes yellow foam. The foam itself is sharper to the feel and it's harder to compress then the other 2 pads. I find the pad too dry and stiff personally but it worked great a few years ago. The results are there of course.
    Just an observation.
    The white foam is super course. I will get a Blue SDO pad today in the post - finally - and i'm thinking it will be softer/less sharp then the BOSS white pad.
    Edit: Just got the blue SDO! Beautiful color and it feels less aggressive then the BOSS white pad.
  5. Thanks oneheadlite thanked for this post
  6. #14
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    8,981
    I agree with this whole post, 100%.
    The G9 has all the balls to churn a 6" set-up, no question.
    Mr. Snoop mentioned that the 5" set up (plate/pads) are cheaper, and he is correct. This is what I run since I already had all of the 5" pads for my PC & GG6.
    As for the BOSS orange pads, I also agree that they seem a "tick" less aggressive than say, a Lake Country orange pad. But not by much at all. And I have no problem reaching for either when I am polishing.
    And ditto for the BOSS Creams. They have become my go-to if I need to do any kind of correction.
  7. #15
    Jun 2019
    355
    One thing i learn the last few days not all lake country orange pads are the same according to their aggression charts.
    For instance the LC orange flat + CCS pads are 6/10 cut and 6/10 finish but the HDO/SDO line the orange is rated at 6/10 cut + 9/10 finish.
    https://www.lakecountrymfg.com/20190909-LCM-Catalog.pdf
    I really like the SDO pads, i have the blue and orange now. They are my favorite pads. The rupes pads are nice too but i like the smaller face and the little extra softness of the SDO pads. I like both lineups better then the BOSS pads. Which i first started with 3 years ago.
    Not sure if its buff and shine or lake country that makes the BOSS pads..I'm guessing lake country.
  1. Griots G9: Griots 5" backing plate vs the one Autogeek includes (yellow one)
    By alkemyst in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-29-2021, 09:54 PM
  2. Worth the upgrade to Griots G9?
    By 04lss in forum Auto Detailing 101
    Last Post: 01-21-2021, 08:25 PM
  3. Griots Boss Air 2" backing plate on Griots 3" mini polisher?
    Last Post: 03-31-2019, 03:08 PM
  4. 370z, having issues using griots one step / griots DA
    By ssdx in forum Auto Detailing 101
    Last Post: 04-12-2014, 10:49 PM
  5. Opinions on clear bras. Worth it or not worth it?
    By AliMusa in forum Auto Detailing 101
    Last Post: 05-17-2013, 12:08 PM
Members who have read this thread: 53
» October 2021
2627282930 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
