Results 11 to 20 of 23
Thread: Griot G9
    Mar 2021
    45
    Re: Griot G9
    Quote Originally Posted by tasdisr View Post
    I currently have a PC 7424 (not the XP) and was considering the purchase of a G9. Would this be an upgrade from the PC 7424. I am only using it on my wifes and my own car.
    My PC is very old, I most likely got it a year or so after it was introduced-my G9 (with the 5 1/2)" kit was just purchased a few months ago. Posting that the G9 would be an upgrade does not even come close to what I observe and I really think you have to see it for yourself. Generally this would be risky and it IS with any other buffer-sorry guys but the truth is the truth-get a G9 try it-I cannot imagine you sending it back.
    Is it perfect? of course not-can you stall it?, of course you can the really big BUT is that one, or at least I- have to put a lot of effort into making it stall at least as much down pressure as I have to exert on my vintage Cyclo .
    Get one you have very very little or nothing to lose and you stand to gain big time.
    May 2013
    Atlanta
    Re: Griot G9
    Quote Originally Posted by MisterSnoop View Post
    I thought if it wasn't direct, you'd be dealing with the place you bought it from if you had a issue. Direct, I believe they also have a 180 day return policy.
    Autogeek regularly does 15% sitewide though.
    The sales I've seen exclude polishers, but you do get rewards for you purchase.
  3. #13
    Sep 2020
    Eastern PA
    1,784
    Re: Griot G9
    Quote Originally Posted by Todd404 View Post
    I referring to a sale like this, which was in May. They're currently doing a sale on $100 gift certificates, which could be used.
  4. #14
    Mar 2006
    Re: Griot G9
    I think I am going to order the 5.5 inch flat pad kit.
  5. #15
    Super Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    269
    Re: Griot G9
    I've only been using 6" pads on my G9 so far (other then 5" glass rayon BP and pad.) Not had issue yet so far other then my technique still needs some practice... Though I do wish in ways I had gotten the older Griots as I could switch it between the 3 and 5 or 6" backing plates. The G9 does seem to get much hotter though in the center spindle/pad compared to the 7424 I had years ago, but its been a long time since I had that so not 100% sure...
    ·Ï¢årµ§·
  6. #16
    Aug 2015
    Andover, MN
    1,727
    Re: Griot G9
    Grab the Griot's 5" backing plate and 5 1/2" pads in your order.
    Yes, the G9 has enough a$$ to churn the 6". But I have found it very unpleasant to use. (Unless you were to be working on the sides of cargo vans all day long).
    That’s interesting you’ve found it unpleasant. Once I got past my mental conditioning from my GG6 days that I’m only supposed to use 5.5” thin pads, I actually found there are times I prefer a thick 6.5” pad (for curves and contours of all places). I’ll use my 6.5” thin pads for big flat expanses.
    Like Paul mentioned, make sure if you get a 5.5” plate you get the Griot’s vented one - the backing plate was designed as part of the machines cooling.
  7. #17
    Mar 2006
    Re: Griot G9
    After thinking about it I was wondering if I would be better off buying the G9 and and the CCS Lake Country 6 pack of foam pads and picking what pads I want. My paint on my Jeep is in pretty good condition so it needs very little correction.
  8. #18
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Griot G9
    Absolutely. But, I think you would be better off getting the LC Flat pads rather than the CCS.
  9. #19
    Mar 2006
    Re: Griot G9
    Any suggestions as to which pads to order?
  10. Thanks rnjroz thanked for this post
  11. #20
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Griot G9
    I would get 6 White and 6 Orange to start with.
    Jeeps tend to have medium/hard clear coat, and I have found the White & Orange to be the best for it.
  1. Griot's G9 ?
    By nkme2000 in forum Ask your detailing questions!
    Last Post: 05-14-2020, 09:46 AM
  2. Replies: 52
    Last Post: 07-31-2018, 05:36 PM
  3. IDA CD In-A-Day at Griot's?....
    By Firehouse Mike in forum 2-Day ROADSHOW Car Detailing Classes - Info & Dates
    Last Post: 05-04-2018, 07:29 PM
  4. Going from Griot's 6 ROP to Meg's V2...
    By DaC in forum Auto Detailing 101
    Last Post: 09-16-2012, 10:52 AM
  5. For those with Griot's DA...
    By Clutch34 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 01-18-2010, 12:51 PM
