» Detailing Classes
Page 13 of 13 FirstFirst ... 345678910111213
Results 121 to 130 of 130
  1. #121
    Nov 2016
    Re: Griot's Garage G15/G21 Long-Throw Orbital Polisher *Ground-Up Redesign*
    Currently have a G9 and was looking to get a G15. The issues with the G9 and a 5 inch backing plate is that with todays newer cars the G9 stalls a lot. So my question is,
    Does the G15 with 5 inch backing plat stall on curves.
  2. #122
    Super Member BSoares's Avatar
    Mar 2017
    Exton, PA
    1,862
    Quote Originally Posted by 2quiker View Post
    G15 will stall more than G9. The longer the stroke of the polisher, the easier it is to stall. Granted some overcome that with extra power but the G9 is plenty strong.
    Improve your technique or buy a Flex for forced rotation, nothing stops that.
    Bruno Soares
  3. Likes PaulMys liked this post
  4. #123
    Aug 2015
    Andover, MN
    1,049
    This may sound counter-intuitive, but try switching to thicker pads or 6.5” pads. I’ve found my G9 actually turns them better on intricate surfaces with less stalling than the 5.5” BOSS pads.
  5. Likes PaulMys, JustJesus liked this post
  6. #124
    Aug 2013
    St Louis metro (Illinois)
    4,385
    Quote Originally Posted by BSoares View Post
    After using my G15 a couple times, I can't imagine how hard I'd have to bear down to stall it out. The motor is pretty stout and drives the backing plate and pads pretty hard. I works hard enough on it's own I've not encountered a situation where I've had to put enough pressure on it to come even close.
  7. Likes BSoares liked this post
  8. #125
    Mar 2017
    Exton, PA
    1,862
    Right, but try lifting it and putting the pad at an angle, it will stall easily. That’s why I said if he was having issues it’s likely due to technique. If you keep the pad flat and put normal amount of downforce the machine will keep pad rotation almost all the time. It would have to be a very curvy panel to give you trouble.
    Bruno Soares
  9. Likes PaulMys liked this post
  10. #126
    Super Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    8,181
    This exactly my experience with the G9, Bruno.
    My first use with mine, I tried to "finesse" or "dance" it on some curved panels. Stall City. Then, I tried attacking it straight on with just a bit less pressure, and it just kept on churning.
  11. Likes BSoares, JustJesus liked this post
  12. #127
    Nov 2016
    So you haven't had your G15 stall?
  13. #128
    Aug 2013
    4,385
    So you haven't had your G14 stall?
    No, I have never stalled my G15, but I don't know if I've even tried to work it in a position like what was mentioned above.
  14. #129
    Nov 2016
    Thanks for the info. To the folks that gave a G9 and G15, are they much different as far as power/ correcting between the two?
    If you have both would you reconsider adding the G15 again or stepping up to a Rupes or Flex.
  15. #130
    Nov 2016
    I got the G15 and I can't make this machine stall, it slows down but man I am very happy I got the G15.
  16. Likes BSoares, dgage, Coatingsarecrack liked this post
  1. Griot's Garage LIVE: G15/21 Long Throw Orbital (2020)
    By VISITOR in forum Griotís Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 09-24-2020, 09:02 PM
  2. Griots Garage BOSS G15/G21 Long-Throw Orbital Polisher Free Bonus! **LIMITED TIME PROMOTION**
    Last Post: 06-14-2018, 11:29 PM
  3. Replies: 85
    Last Post: 04-26-2017, 07:16 AM
  4. Long throw orbital polisher
    By LSNAutoDetailing in forum Auto Detailing 101
    Last Post: 06-08-2015, 08:33 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
Members who have read this thread: 85
» April 2021
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 1
