» Detailing Classes
Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
  1. #31
    Apr 2015
    PGH, PA
    1,400
    Re: 6in Orbital to 15mm
    If the curve is too deep, you simply attack it in 2 sections..
    top of crease first then bottom of crease..
    Hell I've corrected with a stalled 21mm..
    The oscillation of the 21mm with the dragging action of you moving polisher across crease will correct..but still faster to attack by 2 parts vs my massage/scrub technique
  2. Thanks PaulMys thanked for this post
    Likes PaulMys, DETAILROOKIE, AaronE liked this post
  3. #32
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    4,951
    Technique plays a factor.......... Who knew?
    "Simple physics" aside........
  4. Likes DETAILROOKIE liked this post
  5. #33
    Jan 2014
    L.I. NY
    4,951
    Quote Originally Posted by fightnews View Post
    It doesn't matter it's simple physics. If you have a machine that has to be flat to rotate the pad then you are not getting good contact on the contour of a car. You're now only polishing a tiny area effectively and most of the pad is touching air.
    There is no way around this if you have a machine with a pad that has to be flat to spin and a contoured car panel. You can rationalize it until you're blue in the face but it's not going to change that fact.
    So.... A machine that does NOT stall on a curved panel has full contact?
    Last I checked, just about every polisher/backing plate are pretty much flat to start. That is, not one of them can "cup" themselves to a panel that is curved.
    This is where technique comes in.
    A human can lighten up on the pressure, tilt the machine, or otherwise use common sense to make a machine work to their liking.
    Simple physics.
  6. Likes DETAILROOKIE liked this post
  1. Detailing Class - FLEX XFE7-15mm Free Spinning Orbital Polisher
    By Mike Phillips in forum Pictures from Autogeeks 3 Day Detailing Classes with Mike Phillips
    Last Post: 04-06-2018, 02:40 PM
  2. The FINISHER - Updated FLEX XFE7 15mm Orbital Polisher
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-17-2016, 08:46 AM
  3. What's in the box? FLEX Free Spinning XFE 7-15 150 - 15mm Orbital Polisher!
    Last Post: 04-24-2016, 02:15 AM
  4. New Flex Tool XFE 7 - 15mm Long Stroke Free Spinning Orbital Polisher
    Last Post: 03-15-2016, 12:26 PM
  5. Look what came today! NEW FLEX XFE 7 15mm Large Stroke Free Spinning Orbital Polisher
    Last Post: 02-18-2016, 09:29 PM
Members who have read this thread: 95
» August 2019
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
