Results 1 to 5 of 5
    Super Member EWtheDETAILER's Avatar
    Sep 2012
    Princeton, Indiana
    341
    My Flex 3401 has quite....help with Repair needed!
    My Flex 3401 has been slowly dying over this past few months. I found a short in my cord, and repaired it, until my new cord could come in. I've replaced the cord with a factory replacement... It will start and run for about 2 seconds before dying... I've been able to unplug and plug it back in twice since with the same result. It almost seems like I'm tripping a breaker or have a wire loose but can't find either. Any help is appreciated!
    Keep Calm... and Detail On!
    Eric
    Sep 2012
    Princeton, Indiana
    341
    So after some more trouble shooting and Internet searches... I thought I had the speed switch/sensor problem or a potential brush going out...All in all I actually just reversed the white and black wire when putting in the new chord. I'll leave this post up for the next guy that has the same problem! Note to all the Autogeeks... Always take some pictures before digging into the electronics of the industry... Even if it's just 2 wires!
    Eric
    Regular Member TRDTACO's Avatar
    Oct 2014
    Central NY
    175
    Re: My Flex 3401 has quite....help with Repair needed!
    How long have you had it for before you had the issues?What were the symptoms of the bad power cord? I own a Flex allso and would just like to know what issues I may have in the Future.
    2016 TOYOTA TACOMA TRD OFF ROAD PACKAGE
    Sep 2012
    Princeton, Indiana
    341
    I used and abused my Flex 3401 for +4 years before having and problems. I noticed the rubber reinforcement where the cord goes into the buffer housing was really getting worn, and eventually slid down the cord/separated from the buffer. One day it just quite on me. My first response was to replace the cord to ensure it was getting good power before going after brushes or the speed switch. To my luck it was the cord.
    Eric
    Super Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Sorry to hear, there was a thread on some repair places that you can send in for repair.
    I would try to do some searches to find out, as you definitely want your machine to get fixed !
  1. Replies: 5
    Last Post: 09-11-2018, 11:02 AM
  2. Broken Backing Plate on FLEX 3401? Need for repair?
    Last Post: 05-16-2018, 05:21 PM
  3. Flex 3401 Order - What else is needed/recommended?
    By hammargren in forum Ask your detailing questions!
    Last Post: 07-20-2013, 12:49 PM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  5. Advice needed on megs microfiber polishing system/Flex 3401
    By Rez90 in forum Ask your detailing questions!
    Last Post: 09-15-2011, 06:27 PM
