Lake Country backing plate washers
Hi, I've very recently bought a Flex 3401 and also the lake country backing plate system. Mine, as I suspect does all of them, came with no instructions and for the most part does not need them as it's pretty obvious where it all goes.
But there is one thing that up to yet I have not seen mentioned, and that's the two very thin washers. To my way of thinking there is only one place they can go and that's in the recess of the geared plate. They are too wide to fit in the recess of the four or six inch backing pads. The backing pad as I see takes the single thick washer that comes with the bolt. As I've said above ive not seen the two thin ones mentioned on any of the threads ive viewed, neither did it show them on the lake country instructional video on u tube. It's still not good weather wise here in the UK plenty of rain, mist, and fogs so I have not had chance to use it yet. It came to mind whilst I've been viewing posts on the few occasions that there as been instances of little bits of plastic coming off from the area between the geared plate and the machine.
Does anyone else have these washers? Oh and the pack was sealed when I got it so I don't think they have been placed in as an afterthought, or in error.
Re: Lake Country backing plate washers
You are right, the instructions stink and yes, they go between the adapter and backing plate. They are for use with the larger plate.
Hi Parttimer,
thank-you for getting back to me on this, so to clarify the two thin washers are only needed when the six inch plate is used, and they are not required with the four inch?
I'm glad I've found this out before I got to use it or I think I would have left them in for both. I'm not sure if that would have been detrimental but I don't fancy experimenting to find out.
Thanks again
Dave
You are correct, only on the 6" plate!
Once again Parttimer thankyou for clearing that one up for me.
Dave
This thread is a bit older, but could someone who has the system take a couple of photos of how the washers fit and post them? This would be a great help to me and others.
Thanks
I have Mike's book and it is a great help for someone new to the flex and it's accessories (pad recommendations as well).
Guys I got my Flex last week and I also purchased the LC 4 inch backing plate not the 6 inch backing plate. The 4 inch backing plate came with 2 shims. In this thread it is pointed out that the shims are just for the 6 inch backing plate. So, by virtue of the fact that LC included the shims, am I to assume that whatever issue existed with the larger plate also exists with the smaller one and therefore I should use the shims? Or was this a packaging mistake?
By Markymapo in forum Flex Polishers
Last Post: 06-10-2019, 12:25 PM
By nat88 in forum Auto Detailing 101
Last Post: 11-06-2013, 10:03 AM
By ryanmcg1 in forum Product Reviews
Last Post: 09-29-2011, 11:29 PM
By maxisiri in forum Auto Detailing Tools and Accessories
Last Post: 05-04-2010, 04:51 PM
By 87rx7chick in forum Customer Comments
Last Post: 12-05-2009, 02:38 AM
