Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Senior Member Newdetailer1's Avatar
    Feb 2012
    Philadelphia area
    329
    6.5's or 5.5's Flex 3401
    Which do you guys like better overall? I have both and I'm not really sure I care for the 6.5's? I just wanted to get you're guys take on it before I try and unload them somewhere. Help me understand the advantages of the 6.5? To me it seems harder to use and it wanted a lot me product (which makes sense). IDK let me know what you guys think?
    Senior Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Re: 6.5's or 5.5's Flex 3401
    Technically speaking, the area of the two are as follows;
    Surface Area - 5 1/2 pad = 23.75 in²
    Surface Area - 6 1/2 pad = 33.18 in²
    All else equal, the larger pad should be able to correct the area in less time and time is money....
    Feb 2012
    Philadelphia area
    329
    Quote Originally Posted by BobbyG View Post
    Surface Area - 5 1/2 pad = 23.75 in˛
    Surface Area - 6 1/2 pad = 33.18 in˛
    Yeah, but doesn't it take more product to load up the pad? Can you do larger that a 2X2 section or is the idea to do the same 2X2 quicker?
    Senior Member Robert8194's Avatar
    May 2011
    Hoover, AL
    1,045
    Quote Originally Posted by Newdetailer1 View Post
    Theoretically it takes the same amount of product to polish the car. Even if it takes more to prime the 6.5, it is going to go farther. I wouldn't change the size of a section I did but as Bobby said, it should take less time to cover the same area with a larger pad. It probably comes down more to what you are comfortable with. Some people find the larger pads to walk more on the 3401. I think you hit it with your last question. You do the same section faster.
    Feb 2012
    Philadelphia area
    329
    Ok. I guess I'll just give the 6.5's another chance?
    Aug 2011
    The "OC"
    886
    BobbyG is right. Everything being equal, a 6.5" pad has greater surface area and will correct that 2x2 section faster.
    Now there's the preference factor that is completely subjective. To this, I've used 7.5" Chemical Guy self center pads on the 3401 and love it on larger cars.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
    Senior Member Danube's Avatar
    Jan 2012
    Australia
    864
    I personally prefer 5.5" and 4" pads with 3401 but that's a personal preference.
    Flex 3401 & PE14
    Senior Member Bunky's Avatar
    Jun 2007
    Hillsborough, NC
    6,179
    I picked up the new Lake Country backing plates for the Flex.
    It will be interesting to see if the 6-in backing plate changes how a 6.5-in pad performs (hold more of the pad against the plate) both polishing and handling.
    Al
    The Need to Bead
    Mar 2012
    143
    Quote Originally Posted by Bunky View Post
    I'm curious to see how the new LC backing plate affects handling. I tend to be skeptical about aftermarket adapters of any kind for any tool. If they work well, I'm open to changing my mind.
    Regards,
    Dan.
  10. #10
    Jan 2012
    Australia
    864
    Its interesting that so many of the LC adapters were sold, but no review as yet?!?
    Flex 3401 & PE14
  1. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  2. Flex 3401 RPM & OPM
    By mbret2004 in forum Flex Polishers
    Last Post: 06-12-2013, 10:12 AM
  3. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  4. Flex 3401
    By Diversion in forum Flex Polishers
    Last Post: 04-02-2012, 08:09 AM
  5. Flex 3401 OPM
    By skipper1 in forum Flex Polishers
    Last Post: 11-17-2010, 05:15 PM
» May 2017
30 1 2 3 4 5 6
28 29 30 31 123
