Results 1 to 9 of 9
    Super Member Josh@BR's Avatar
    Dec 2010
    Hagerstown Maryland
    206
    Adjusting 3401 Handle?
    So I recently just got to use my Flex for the first time last night. It takes a little to get used to but overall is MUCH nicer and smoother than my pc. The only thing I didnt like is the stock placement of the handle. I dont like having to reach over the buffer pad to hold it. The handle looks like it adjusts using the supplied allen key but I removed the handle piece from the buffer and it seems theres no way to change the position of the handle. I read somewhere here that it can be adjusted to your liking but couldnt find it in the owners manual either. Any advice or is this not possible? Thanks
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Re: Adjusting 3401 Handle?
    Personally I have found that I like the side handle better than the front handle.... there's really not much adjustability with the "bail" setup. that would move the grip behind the pad.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
    Super Member A4 1.8tqm's Avatar
    Apr 2009
    Edmonds, Wa.
    1,932
    I thought it was adjustable when I first got mine too, it's not. I learned with the Flex so it's handle is "normal" to me. I'm planing to dremmel away part of my stick handle so it will screw on in place of one of the allen head screws while the bail handle is still on. We'll see how that turns out...
    Apr 2009
    Edmonds, Wa.
    1,932
    I did it, both the bail handle and stick handle at the same time on my 3401. I couldn't find the handle on it's own in the AG store, it's the one that came with my FLEX L3403. Just thought I'd share some pics in case you want to do the same.
    sanded down the sides so it's skinnier-
    Now it will fit into the hole meant for the Allen head screw-
    Fit's nice and tight. Done in 5 min-
    Super Member jimmyjam's Avatar
    Nov 2010
    Visalia,CA
    677
    I have this one...
    I don't want it to look wet, I want it to look Soaked!
    Super Member jpegs13's Avatar
    Oct 2009
    Manhasset, L.I. NY
    1,908
    Personally, I don't use the side handle, I like the feel without it.
    John
    Mean people suck
    Nov 2010
    Visalia,CA
    677
    Quote Originally Posted by jpegs13 View Post
    I have the handle, but I haven't installed it yet. I'm gonna give it a try this week, we'll see....
    Sep 2017
    Quote Originally Posted by jimmyjam View Post
    I broke my handle by moving it to a from its normal factory setting. Just ordered a new one, becuase the machinge gets hot..
    I do not think you can move the handle, I may be wrong. I may have moved the handle incorrectly, but it broke right away
    I would like to know.
    Nov 2017
    I wish it came with a D handle like griots garage polisher
  1. FLEX 3401 Bail Handle Bolts - Installation and Tightening
    Last Post: 04-16-2020, 11:16 AM
  2. Rotary Buffer- Stick Handle - Hoop Handle - Or no handle at all
    Last Post: 04-24-2019, 06:53 AM
  3. 3401 replacement bail handle?
    By Lambo1 in forum Flex Polishers
    Last Post: 06-28-2015, 06:44 PM
  4. 3401 Handle
    By RFulmer in forum Flex Polishers
    Last Post: 12-15-2013, 06:51 PM
  5. WTB: SoftVib side handle for Flex XC 3401 VRG
    By ZoranC in forum Off-Topic
    Last Post: 08-08-2008, 06:45 AM
