First Machine Polishing w/Flex 3401
Hello everyone,
This weekend will be my very first time using/polishing w/DA machine (via Flex 3401). I have SIP, 106FA, and 85RD with orange, white, and blue LC pads to remove some light scratches/marring from my wife's white MB E500. Then a few coats of 4star UPP sealant and a coat of SSII wax. I do have a few Q's:
1. Do I need to moisten or wet the pad and with what?
2. How do I know when to stop polishing or when the Menzerna has been broken down?
3. Any other hints or suggestions?
I've seen some video here or on the internet, but they are not that thorough and in low resolution, so it was very difficult to tell.
Thanks!!
SELF BANNED
Re: First Machine Polishing w/Flex 3401
I would start out with SIP on the white pad then follow up with 85RD on a blue finishing pad. I don not prime my pads with anything, if you decide to just mist it with water, do not use a QD. The Menzerna will turn to a clear oily look and that is when it is broken down. If that doesnt get the swirls out then go to your orange pad with SIP and once again follow up with 85RD on a blue pad. You always finish with a finishing polish on a finishing pad.
Originally Posted by Maison
Hello everyone,
Thanks!!
You should go to the Auto Detailing Forum, at the top there are two "stickys" to provide info. on how to use Menzerna and how to know when it breaks down.
Moisten - use distilled water
Howard
1st thing is 1st.. make sure the backing plate is properly seated... you will know when you have seated the backing plate properly because it will be PERFECTLY flush with the threaded spindle that goes into the backing plate and you will hear it "snap".. always make sure the backing plate is TIGHT
By doing this I believe the issues you may have read about with the backing plate shedding plastic shaving could be avoided
www.deep-gloss.com
Deep Gloss Auto Salon / Fine Automobile Detailing - Metro Detroit's Paint Correction Specialist
For Discriminating Automobile Enthusiasts Who Demand The Best
South East Michigan Automotive Detailing - Rochester Hills, Troy, Bloomfield Hills, Birmingham, Farmington Hills, South Lyon, West Bloomfield, Ann Arbor, Grand Rapids, Brighton, Grosse Point, Shelby Twp, Utica, Beverly Hills, Berkely, Walled Lake, Livonia, Novi, Wixom, Waterford, Clarkston
Administrator
also make sure to apply a bit of oil on the felt ring.
"The true spirit of conversation consists in building on another man's observation, not overturning it." Edward G. Bulwer-Lytton
Thanks for the responses so far. Some say to moisten and others not, guess I'll try w/o it. Did check proper seating of back plate and tightness when I received it. Not sure if I wanna the oil application though. The countdown begins, I'm startin' first thing Friday AM.
SELF BANNED
Good luck and let us know how it goes.
My two cents, I moisten the pad, only because most of my work is outside. You won't hurt anything by doing it or not doing, mostly personal preference around here
By mats in forum Auto Detailing 101
Last Post: 09-20-2018, 11:02 AM
By delboy828 in forum How to Videos
Last Post: 03-29-2016, 04:26 AM
By Hermes1 in forum Flex Polishers
Last Post: 11-13-2015, 01:33 AM
By dsjohn in forum Ask your detailing questions!
Last Post: 08-08-2012, 06:06 AM
By jimmers in forum Show N' Shine
Last Post: 03-22-2010, 03:31 PM
