Re: Next choice: question about polishers.
Are you swapping batteries at 2 bars remaining and that still gave 40 minutes at max speed without losing power?
Took me 1 hour and 10 minutes to do a one step production detail to this SUV - including every square millimeter a top to bottom.
Gear-driven orbital saves you time while putting out pro quality results.
Hang tight - will make a video.
Here’s a video I just made
Mike Phillips - 1 hour and 10 minutes to do a One-Step...
Awesome video! Car looks great.
So in your opinion, how much less power is this versus the super beast? Do you need to change batteries around 2 bars to maintain maximum power?
Nope.
On the first battery - I ran it until it died running.
And for what it's worth - for every body panel I did my normal downward pressure, arm speed and number of section passes jut like I was using a corded model.
Before this car went to the body shop we did a full exterior paint correction and coating. It sat outside when not being worked on for 2 months at the local Infiniti dealership. The paint, glass and trim had water spots and surface contamination. Not the dealership's fault - just the normal thing that happens when you have a daily driver parked outside 24x7.
It's almost 4:00pm and I'm calling it a day. Tomorrow after work I'll coat the glass and apply the 303G
Yeah - she just glistens in the garage.
I'll stick to what I shared in post #3 in this article,
FLEX Power Tools Nicknames - All cool tools should have a nickname - not a part number -Mike Phillips
Here's my take on the above 3 gear-driven tools
The BEAST
If I REALLY want to bust out a job and plow through it as fast as humanly possible I use the BEAST.
The Supa BEAST
If not trying to hit Warp Speed - I grab the Supa Beast, much more enjoyable to use. Amazing tool. Smoother, quieter, lighter and cooler than the original.
The CBEAST
If I have an easy job, that means the car has only light swirls, scratches, etc. and I'm not in a hurry then I grab the CBEAST.
I have changed my mind about the 6" backing plate. I much prefer it over the 5" factory backing plate WITH the right pads and right now my favorite 7" pads for the 6" backing plate on the BEAST, the Supa BEAST and the CBEAST are the RUPES yellow and white pads. I'm still not liking the new RUPES blue foam formula.
When cutting or compounding with the BEAST and the Supa BEAST I'm still using the Lake Country Force Hybrid 6.5" Orange Foam Cutting Pad. I'm not sure I'll like this shape or thickness on the CBEAST though. Will do some searching and experimenting.
The CBEAST is a very capable tool. The ability to buff out a car without a power cord is awesome. The GEAR-DRIVEN aspect means no wasting time wit pad stalling. And larger TAPERED foam pads work best with these 3 tools.
Yes. Max power does fall off but I have not monitored at what point. Still - I'll take a a slower rpm/opm with a gear-driven orbital all day over a free spinning.
The BEASTS - All BRAWL - ZERO STALL
Hope that helps...
dgage thanked for this post
The BEAST
The Supa BEAST
The CBEAST
Hope that helps...
Thanks so much Mike.
I think you convinced me to get both cbeast and supe beast to replace my rupes.
The BEAST
The Supa BEAST
The CBEAST
Hope that helps...
Hi Mike,
The cbeast, versus super beast, how much less power do you feel its losing vs the coded?
And is it still enough to do cutting and paint correction?
As a professional tool collector, that is definitely one option. Just wondering though if you should get the CBeast first and try it out to see if you even need the SupaBeast. Maybe instead of spending money on the Supa you could buy another battery and be able to go constantly with the cordless. Sometimes ignorance is bliss.
By Automoglow in forum Auto Detailing Tools and Accessories
Last Post: 04-17-2018, 08:25 PM
By snfapm1983 in forum Auto Detailing 101
Last Post: 04-08-2013, 08:19 PM
By Matt_F in forum Auto Detailing 101
Last Post: 05-08-2012, 06:12 AM
By Bill1234 in forum Auto Detailing 101
Last Post: 04-27-2012, 08:08 AM
By ballfan4141 in forum Auto Detailing 101
Last Post: 09-18-2009, 10:49 PM
