Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Re: Flex 3401 in Phoenix?
    Quote Originally Posted by gr8almty1 View Post
    Disregard my question, I found a write up by you
    Share the link to the write-up here please. I have so many articles on so many things I can't always find or remember what's where.
    In a nutshell,
    If I want to go as fast as I can to plow through a car I use the BEAST.
    If I want to go fast but it's not vital to plow through the car I use the Supa BEAST.
    If I'm not in a hurry or doing something like machine applying a wax or sealant I use the CBEAST
    The lighter, quieter, cooler running Supa BEAST is my preferred option for these three characteristics.
    I detailed a car on Friday and Saturday and for both cars I used the Supa BEAST.
    Aug 2015
    43
    In a nutshell,
    Amazing tool. Smoother, quieter, lighter and cooler than the original.
    It does not have the same maximum RPM or OPM as the original.
    BEAST = 480 RPM and 9,600 OPM
    Supa BEAST = 430 RPM and 8,600 OPM
    CBEAST = 380 RPM and 7,600 OPM
    Here's my take, if I REALLY want to bust out a job and plow through it as fast as humanly possible I use the BEAST. If not trying to hit Warp Speed - I grab the Supa Beast, much more enjoyable to use. If I have an easy job, that means the car has only light swirls, scratches, etc. and I'm not in a hurry then I grab the CBEAST.
    Best pads I've found for the BEAST and Supa BEAST are either the Lake Country 6.5" Force Hybrid Pads, I can pretty much do anything with Orange, White and Black.
    I also really like the RUPES 7" foam pad, in all colors, just depends on the project. For polishing gel-coat - the blue and green. For polishing car paint - the yellow and white. I like the TAPERED edge on the RUPES pads as it works well with the reach and buffing characteristics of the gear-driven 8mm tool action.
    For the CBEAST - at this time I don't think there's a PERFECT pad for this tool but I do like the Buff & Shine Uro-Tech pads.
  3. #13
    And for those reading this into the future, here's the link to the reply I wrote with the above info in the seconded quoted section above.
    Anyone have experience with the new corded XCE compared to the 3401?
  1. Flex 3401 or FLEX XFE7-15
    By DETAILROOKIE in forum Auto Detailing 101
    Last Post: 05-25-2017, 10:49 AM
  2. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  3. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  4. Flex 3401
    By Sailordotcom in forum Auto Detailing 101
    Last Post: 08-23-2010, 10:59 PM
  5. Which 3401 flex kit?
    By tephra in forum Flex Polishers
    Last Post: 06-18-2010, 08:30 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
