Results 11 to 20 of 22
    Feb 2015
    59
    Re: Attention Flex PiXiE Owners.
    Thanks Mike, I will leave you alone now. Sorry
    Super Member Markymapo's Avatar
    Jun 2018
    Audubon,PA
    662
    Thanks for the info. Can’t wait to try this out ( been crazy busy at work, running 7 days a week 2 shifts to keep social distancing in the research labs). Will most likely use on my Cobalt bow rider once the lockdown is lifted ( our community dock can’t go in the water due to business shutdown in PA)
    2022 Carrera S & Honda CRV Hybrid
    2015 Lexus IS 350, 2016 Ford F-150
    Cobalt 242 (8.1 L block, Volvo outdrive)
  3. #13
    Feb 2015
    59
    Just depends on the pad. Most 3" pads I can think of - the FACE of the pad is always a tick larger than 3" and the backing is right at 3" so the pad should fit fine.
    What do you have for pads?
    I dont yet Mike, looking to get the PXE and wanted your advice on the pads as I was a little confused as you know. In the uk we are a bit limited, so really I should be looking for any 1" and 3" pads ( the velcro size) ?
  4. #14
    Feb 2015
    59
    What I do not understand is why Flex seem to do odd backing plate sizes ?
    Now I'm obviously being really dumb, so please tolerate my ignorance in the matter, if anything, to educate me.
    But this machine comes with 30mm and 75mm backing plates, so the 75mm makes sense as that is 3" and there are lots of 3" pads, the 30mm doesnt make sense to me though as that is larger than 1", so surely 1" pads will be slightly too small and the backing plate will be larger than the mating surface of the pad?
  5. #15
    Quote Originally Posted by nickyc View Post
    But this machine comes with 30mm and 75mm backing plates, so the 75mm makes sense as that is 3" and there are lots of 3" pads, the 30mm doesn't make sense to me though as that is larger than 1", so surely 1" pads will be slightly too small and the backing plate will be larger than the mating surface of the pad?
    Here's the deal,
    You want and need the velcor on the back of ANY pad for ANY backing plate to be the exact fit or a little oversize.
    If it's exact fit then it's easy to center the pad on the backing plate and this is important for any free spinning random orbital polisher as having the pad off-center an slow down pad rotation.
    If it's oversize, that's okay, you can use your EYES to center the backing plate against the Velcro backing.
    The PROBLEM is if the back of a buffing pad is SMALLER than the backing plate. If this is the case, then it's really difficult for your eyes to center the pad.
    FLEX makes 1", 2" and 3" foam pads that work great on this tool and should be available somewhere in the U.K.
  6. #16
    Here's link to FLEX pads on the AG store
    FLEX PE8 Rotary Foam Pads 1, 2, 3 Inch Diameter
    They only weigh a little more than air so they should be somewhat cheap to ship.
    I know the guys at Motorgeek.co.uk - good guys.... here's some 1" and 3.5" pad options.
    Lake Country Force Hybrid Foam Pads - 1" MINI Pads
    Lake Country Force Hybrid Foam Pads - 2"MINI Pads
    Lake Country Force Hybrid Foam Pads - 3.5"
    Stiffer pads like polishing and cutting rotate better on small tools than soft squishy pads.
  7. #17
    Feb 2015
    59
    Thats what I mean Mike, the 30mm backing plate will be slightly too large for the mounting face of a 1" pad as that will be closer to 25mm in theory ?
  8. #18
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    I can vouch that these fit great and work really nice in the 1 inch Velcro plate. I generally use the 1 inch pads in rotary mode.
    1 inch Buff and Shine Uro-Tec Foam Pads
    Jim
  9. #19
    5mm is pretty small and most of these measurements are not exact, at least on the pad side of the equation.
    Here's what I would recommend, order just ONE pad from your supplier in the U.K. and check it for fitment. If it fits, order more pads. If it doesn't fit - you're only out the cost of the pad and shipping but my guess is it's going to fit.
  10. Thanks nickyc thanked for this post
  11. #20
    Super Member theamcguy's Avatar
    Dec 2007
    Fayetteville, NC
    260
    I sure hope Flex comes out with a 2" pad soon. I definitely will order one.
    Bill Strobel
    Owner Independent Towing & Repair
    Fayetteville, NC
    Do It Right or Don't Do It At All
  1. Flex "Pixie" PXE80 extensions and attachments?
    By Mike Hoekstra in forum Flex Polishers
    Last Post: 11-23-2020, 10:28 PM
  2. FLEX Live PiXiE giveaway!
    Last Post: 11-04-2020, 08:01 AM
  3. Flex Pixie and headlamp polish
    By Mike Hoekstra in forum Show N' Shine
    Last Post: 09-18-2020, 09:38 PM
  4. Some thoughts on the Flex PXE (PiXiE)
    By Dr Oldz in forum Flex Polishers
    Last Post: 09-18-2020, 08:32 PM
  5. Can I tackle these thin sections on this Pontiac G8 GXP with the FLEX Pixie?
    By Jacob Harrod AUTOCLEAN in forum Ask your detailing questions!
    Last Post: 08-31-2020, 09:10 AM
