Results 1 to 5 of 5
    Aug 2018
    124
    Could a FLEX XFE 7-12 80 Owner please check the backing pad dimensions please?
    I would like to use the Flex XFE 7-12 80’s Standard part # 454.141 75mm Velcro Backing pad, on my Makita PO6000C.
    It appears they both use same type of drive stub, and are secured by a single hex head bolt.
    The bolt on the Makita is an M8 or 8mm thread diameter.
    Of course it means The Flex backing pad needs to have an 8 mm hole to take the securing bolt, and to know if the drive lug with the flats either side is the same size!
    Shaft is 16.82mm across the flats x 18.88mm on the curved part
    Backing Pad is 16.86mm across the flats x 18.96mm on the curved part. The recess is 4.26mm deep.
    note if I was very Lucky, I might find someone who owns a Makita PO5000C and the Flex 75mm XFE 7-12 80
    I would be grateful , If any Flex 7-12 80 owners could let me know.
    thanks
    Peter
    Newbie Member Black Lab's Avatar
    Oct 2016
    South of Chicago
    Re: Could a FLEX XFE 7-12 80 Owner please check the backing pad dimensions please?
    A quick measure with cheap calipers says my XFE 7-12 has:
    M6-1.0x20 allen flange screw (4mm key size)
    Shaft: 16.90mm across the flats, 19.10mm on the rounds
    Plate: 16.99mm across the flats, 19.34ish mm on the rounds. Recess: 3.80mm
    Just some quick measurements, maybe someone else can chime in with more precise ones.
    Aug 2018
    124
    Quote Originally Posted by Black Lab View Post
    Thanks so much for measuring everything.
    The recess looks a bit longer, but should fit.
    Bad news it uses a 6 mm bolt .... more work needed to expand that to accomodate the Makita Bolt
    Very much appreciate the measuring
    Regards
    Peter
    Oct 2016
    South of Chicago
    No problem! Keep us updated on how things go, and good luck to you. Worse comes to worse, you could always pick up a 7-12 80, lol! It's a handy little tool. Also, welcome to the board!
    Aug 2018
    124
    Yes the 7-12 80 .. would be a great complimentary polisher to the Makita
    I only bought mine to correct some cement tile-cutter dust, that attached itself to the car when it rained.
    Fortuneately multiple snow foam washes detached it, so I only really needed the Makita to gloss up any fine scratches one may get with a Clay Bar.
    The little Flex would be very useful on the Bumpers and a few tight curves.
    Naturally I want usage out if the Makita in future on other cars etc.
    If only I could get a 3” backing pad .. that would do me for now.
  1. FLEX XFE 7-12 3 in. Backing Plate on a FLEX XFE7-15 ???
    By MichaelD in forum Ask your detailing questions!
    Last Post: 03-11-2019, 07:49 AM
  2. Check out our recent FLEX shipment!
    By Andre in forum Off-Topic
    Last Post: 02-04-2016, 11:31 AM
  3. Replies: 12
    Last Post: 03-07-2015, 08:31 AM
  4. New Flex XC 3401 Owner … needs a little expert advice
    By OkeefenokeeJoe in forum Flex Polishers
    Last Post: 01-09-2014, 12:25 AM
  5. Pictures: Surbuf MicroFinger Buffing Pads And Backing Plates Plus Dimensions
    By Mike Phillips in forum Wool & Foam Buffing Pads
    Last Post: 04-12-2010, 03:37 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
