Results 11 to 20 of 36
    Aug 2010
    New Jersey
    13,791
    Re: Possible damage to my 3401
    Hopefully you didn't damage the motor. I think Mike Phillips just mentioned recently that the Flex machines have a thermal cutoff, so hopefully that protected the motor.
    Jan 2016
    124
    I bought a HF cheap rotary for boats and gel coat. Comes with a wool pad that does pretty good for boats as well.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  3. #13
    Senior Member hoyt66's Avatar
    May 2011
    Lake Orion Mi.
    2,056
    thank you for the replies.. better get this stuff ordered:-(
    2012 Dodge Challenger RT Classic
  4. #14
    May 2011
    Lake Orion Mi.
    2,056
    Parts ordered! Can't wait to get my Flex right again!
  5. #15
    Senior Member Kamakaz1961's Avatar
    Aug 2013
    Tustin, CA
    3,768
    Quote Originally Posted by hoyt66 View Post
    Once you take your Flex 3401 apart you will realize how easy it is to repair. Zem Germans made it to where simpletons like me can repair it. If I can repair it you can to!! LOL Please give an update when it's all done and ready to rock again!
    CJ
    Save the Manual!
  6. #16
    Sep 2016
    139
    im sure you checked this..but was the locking nut tight on the backing plate?
  7. #17
    May 2011
    Lake Orion Mi.
    2,056
    Quote Originally Posted by Toolhead View Post
    Do you mean the screw that holds the backing plate on? That was tight when I unscrewed it to take the plate off. Or is there something else I can check? Thanks for your help
  8. #18
    May 2011
    Lake Orion Mi.
    2,056
    Received my replacement parts in the mail today. Pretty quick fix and easy fix. Looking back my error was laying to hard on the polisher and not evenly either. I was bending the backing plate thru the felt ring and into the metal part of the polisher housing causing the damage. Lesson learned 70 bucks!
    Good to go!!
  9. #19
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    2,295
    Glad you got it fixed, man.
    And, I truly realize I might bring down a hail storm of attacks on me with next line:
    For almost $450 bucks, I would want to "Lay on" this unit as hard and long as I wanted to without worrying about a plastic gear, or anything else for that matter failing on me. JMO.
  10. #20
    Junior Member Black Lab's Avatar
    Oct 2016
    South of Chicago
    Well, no attack or anything, but what makes you think that paying a higher price for a tool gives you an excuse to use it incorrectly? If I pay $50 for a Snap-On screwdriver, then I should be able to use it as a pry bar, ice-pick, or hammer? I'll never understand this reasoning
  1. wheel damage
    By Tojo912 in forum Auto Detailing 101
    Last Post: 10-02-2015, 10:59 PM
  2. HELP - Damage to Flex 3401 backing plate
    By Nibby99 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-07-2014, 11:12 PM
  3. 3401 plate damage
    By ludrady in forum Flex Polishers
    Last Post: 07-03-2014, 03:11 AM
  4. armor all damage?
    By jonn127 in forum Auto Detailing 101
    Last Post: 04-08-2014, 09:14 PM
  5. Ever damage someone's car?
    By Meticulous-Detail in forum How to make money detailing cars
    Last Post: 11-28-2011, 06:54 PM
