anyone??..new flex 3401 backing plate is off center from the silver/ housing
i just received my flex3401.. new user ..
i went to change out to the flex oem 4 3/8" backplate and immediately notice that the plate is off center.. about 3 3-5 centimeters.. this is estimate..did not measure.. i partially see the felt ring on one side about 2 millimeters of the felt ring is exposed..
after seeing this.. i removed the 4 .xx plate and reinstalled the stock plate.. that plate is off center as well.. same off center location as the 4 .xx" plate.
yes, both plates are seated correctly, i had to adjust the spindle to ensure the plate seated correctly.
is this normal or a defective unit..
doesn't seem right.. especially with part of the felt ring exposed??
anyone .. ?
Re: anyone??..new flex 3401 backing plate is off center from the silver/ housing
It will be off center because of the 8mm throw.
okay.. i actually just measured the housing to the back plate bolt center
the housing (aluminum colored housing with the worm gear drive teeth etc. is 4 4/16" or 4 5/16" .. im using measuring tape.. not my digital caliper..
dead center of the back plate hole center, in the housing, is 2".. ...
is it safe of the 4 3/8 backing plate to have exposed felt. i guess when you place the pad.. the felt is not exposed to the spent product which may dust off..
By Mbout in forum Flex Polishers
Last Post: 02-07-2015, 01:01 AM
By NY-Bondo in forum Auto Detailing 101
Last Post: 03-24-2013, 10:31 AM
By jimmyjam in forum Flex Polishers
Last Post: 03-28-2011, 01:27 PM
By gewb in forum Flex Polishers
Last Post: 02-14-2011, 01:04 PM
By tuscarora dave in forum Flex Polishers
Last Post: 09-27-2010, 04:11 PM
25 | 26 | 27 | 28 | 29 |
