Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Jul 2016
    3,328
    Re: 3401 backing plate.
    Quote Originally Posted by Jeremy1976 View Post
    Not great reviews....
    It works i have it, its just that the hybrid pads are discontinued. force flex are the replacements. the 5" are still good for tight areas though, im still going to use mine
    Jul 2016
    3,328
    I don't think cutting the 4 3/8th plate is a good idea. If you only want to but 1 backing plate then buy the 4 3/8th plate and leave it intact. You can still use the 5" hybrid pads. The velcro is only going to be 3/16ths of an inch over the white felt on the 5" pad. Thats nothing and you will still have over a 1/4" of pad sticking out past the backing plate the whole way around
    That should be plenty seeing as a lot of people use 6" pads on 6" backing plates all the time with no pad over hanging the backing plate
  3. #13
    Jul 2016
    3,328
    Quote Originally Posted by FlyinLow View Post
    Dang, that is the second amazingly clever idea that I've gotten off of this forum today. You guys are amazing!
    I'll make one suggestion though… Rather than taping the edges, sand them, and apply epoxy to seal them. That way, you're actually getting more air in there, which will help keep the pads cooler. Just a suggestion.
    @Demonizer: It's been a few years now so you should know if not having the outside edge of plastic weakens the revised backing plate at high rpm's/pressure. By the way, how did you find a machinist on craigslist? What were your search terms? (hope he sees this)
    not really how much do you think the machinist would charge to mill the plate down? its only 30 bucks for the right one.
  4. #14
    Regular Member FlyinLow's Avatar
    Feb 2017
    San Diego, CA
    144
    Machinist charged him $5
    1994 300ZX 2+2 MT, sole owner, 239K mi
    2005 Ford Escape XLT Sport 4WD
    2014 Maserati Quattroporte GTS
  5. #15
    Apr 2012
    Quote Originally Posted by fightnews View Post
    well that was a bad idea, the 5" hybrid pads are out, The new force flex 5.5 pads are in. you need the 4 3/8th backing plate for them.
    i just went through all this thats how i know
    Thanks for the heads up.
    I was not aware that the Hybrids were no longer the "go to" pads for the flex. Makes sense seeing that they were on the BOGO to most likely get rid of excess inventory.
  6. #16
    Apr 2012
    Anyone looking to buy the 4" Lake Country backing plate should take a look at Autogeek's Special Values page.
    They have the backing plate and a set of 6 - 5" Hybrid Finish Pads for $35.00. That's about what I paid for my Lake Country 4" backing plate a year ago.
    FLEX XC3401 4 inch Backing Plate & Lake Country Hybrid Combo
    I know it was mentioned that the Force Flex pads were the new hot item for the Flex 3401 however anyone looking to save some money or increase their Flex 3401's polishing ability should think about this kit.
  7. #17
    Super Member TheCougarGuy's Avatar
    Apr 2010
    Livonia, Michigan
    588
    Quote Originally Posted by VdubbinMI View Post
    I needed some new 5" hybrid pads and I saw this combo in the special values section and it was a no-brainer. What I didn't realize is that the 5" pads were discontinued. I guess I'll be going back to 5.5 inch pads when I need to restock.
  1. Flex 3401 + LC Backing Plate kit?
    By Mbout in forum Flex Polishers
    Last Post: 02-07-2015, 01:01 AM
  2. Flex 3401 Backing Plate
    By NY-Bondo in forum Auto Detailing 101
    Last Post: 03-24-2013, 10:31 AM
  3. 3401 Backing Plate Combo
    By Crazy Amos in forum Flex Polishers
    Last Post: 03-03-2013, 05:35 PM
  4. Pads for standard backing plate on a 3401
    By Smurf in forum Flex Polishers
    Last Post: 08-07-2012, 05:09 PM
  5. Flex 3401 Circumcised Backing Plate
    By gewb in forum Flex Polishers
    Last Post: 02-14-2011, 01:04 PM
