» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Jun 2009
    Stuart, Florida
    44,987
    Re: Flex PE14-2-150 speed dial problem
    Just to chime in...
    I've spoken to Bob Eichelberg about this issue in the past and he states the exact thing Mike said and the problem starts with the host country's electrical system.
    Fixing your PE14 and then using it with the step down transformer will just lead to the tool malfunctioning again.
    If you like the compact size, RPM range, fit and finish of the FLEX PE14 and plan on doing buffing work with a rotary buffer for the long run the the best solution would be to purchase a FLEX PE14 built for and sold in your country.
    Not sure if that helps but that is the reality of the deal.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
    Senior Member Mike@DedicatedPerfection's Avatar
    Feb 2011
    Belleville Il
    12,251
    Just to chime in...
    That's exactly where I got my information from. The man himself Bob Eichelberg. Not only from him but others at FLEX while there in person.
    Smack tours Flex-tools GmbH Germany!
    I Wanted to share with the OP my situation so he had an idea of what he is doing.
    I also agree the best course of action would be to buy the machine from his market. Using the transformer will take out the speed control. Its just a matter of when the speed control kicks the bucket when used in this method.
  1. Griots's GG3 speed dial- sloppy or tight?
    By SwedishRider in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 04-26-2017, 07:31 PM
  2. flex pe14-2 /150
    By dragan75 in forum Flex Polishers
    Last Post: 05-05-2016, 06:13 PM
  3. Question about 7424XP Speed Dial
    By MarkD51 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-06-2012, 08:11 PM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
» February 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
