Autogeek Class Schedule at Mobil Tech Expo 2013
Here's a list of our classes, location and times...
Thursday January 17th, 2013 – Education Day
How to detail a car – Order of steps - 9:30am to 10:15am Oleander Room
The order in which you tackle a detailing project can either help you or slow you down. When detailing cars for dollars time is money. You will learn which areas of the car to detail first to reduce the total time invested in any detailing job to maximize profits while reducing overall time per detailing project. One of the most common problems detailers make is duplicating steps, which wastes valuable time.
Detail Faster with the Flex XC3401 - 11:45am 12:30pm Sawgrass Room
There are a lot of tool options available for making money detailing cars. Each type or category of tool has its strong points and its short comings. You will learn how to turn the Flex 3401 Forced Rotation Dual Action Polisher into your own money making machine when doing production detailing and even show car detailing.
How to properly use the Rotary Buffer - 12:45pm to 1:30pm Sawgrass Room
The rotary buffer is without a doubt, the most powerful tool there is for machine polishing cars, trucks, boats and Motorhomes. It’s the tool of choice for removing sanding marks after wetsanding an entire car or an isolated repair. The rotary buffer is also to blame for the majority of all the holograms you see all too often in a car freshly detailed by Dealerships, Body Shops and “yes” even supposedly Professional Detailers. You will learn tips and techniques gained over a lifetime from using the rotary buffer including compounding with wool pads, polishing with foam pads and jewelling paint for a hologram-free finish.
Isolated Scratch Removal - 3:30pm to 4:15pm – Sawgrass Room
With the introduction of high quality, ultra fine grit sanding discs, you can now remove isolated defects by safely sanding them out and then safely removing your sanding marks. Performed correctly, no one will ever know there was a defect or that the area was sanded and buffed. You will learn tips and techniques for dampsanding using 3M and Meguiar’s #3000 and #5000 finishing discs and then how to quickly remove all traces of the sanding procedure.
Microfiber Pads - 4:30pm to 5:15pm - Sawgrass Room
Microfiber pad technology is the new hot trend for machine polishing paint and in this class you will learn how to match the right pad to the right tool to get the best performance out of microfiber pads. You'll also learn product selection to match the right chemicals with your microfiber pads for specific paint polishing procedures. Plus how to clean your microfiber pads on the fly to keep them working at maximum efficiency throughout your detailing project.
Renewing Exterior Trim - 5:30pm – 6:15pm Sawgrass Room
So many new cars, trucks and sports utility vehicles utilize plastic, rubber and vinyl trim to reduce both weight and costs when manufacturing new vehicles. The problem with exterior trim material like this is it fades, oxidizes and turns ugly gray with repeated exposure to outdoor environments, UV rays from direct sunlight, and the drying out effect from repeated car washing and inclement weather. In the past most dressings were topical and would easily wash off. Advances in technology has introduced a new selection of exterior trim dressings that last longer and look better for customer pleasing results.
Friday
No Classes on Friday Saturday, January 19th, 2013
Saturday
How to detail a car – Order of steps - 11:30am to 12:15am Oleander Room
The order in which you tackle a detailing project can either help you or slow you down. When detailing cars for dollars time is money. Learn which areas of the car to detail first to reduce the total time invested in any detailing job to maximize profits while reducing overall time per detailing project. One of the most common problems detailers make is duplicating steps, which wastes valuable time.
Last Post: 02-05-2020, 04:56 PM
Last Post: 02-01-2016, 03:21 PM
By Mike Phillips in forum Company & Forum News Headlines
Last Post: 01-07-2014, 11:02 AM
Last Post: 01-15-2013, 07:52 PM
