Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Junior Member hbrett29's Avatar
    Jan 2014
    Philadelphia, PA
    44
    Boat Restoration
    Okay guys, nothing fancy here but I'm trying to restoring two early 80's laser sailboats. I'm planning out my restoration for the spring. I'm wondering if anyone has experience with this oxidized of a boat. I'm hoping to get away without wet sanding, using a heavy marine compound with a rotary and wool cutting pad. Then depending on the results either a medium grade followed my an ultra fine, or simple an ultra fine if that will remove the compounding marks.
    Do you think this can be restored without wet sanding or repainting? They are both in about the same condition.
    Attached Thumbnails Attached Thumbnails Boat Restoration-green-jpg   Boat Restoration-yellow-jpg
    Oct 2012
    133
    Re: Boat Restoration
    From the pictures the gel coats seem to be in decent shape.I know you said you would like to get away without sanding but.... Alot of people simply polish a boat out only to be back where they started from in a few months. The scotchbrite sanding pads might be a better choice for you. This will remove the oxidation ratner then move it around. Gel coats are very forgiving compared to vehicles.Watch a couple You tube videos on subject and go to town.You will use alot of product so Find a bulk gallon of auto/boat compound that has a textue like rocks in a bottle and paint it on if you decide not to sand.I hope that was helpful.
    Jan 2014
    Philadelphia, PA
    44
    If I have to sand to get good results then that's what I'm going to have to do. I would rather do it right the first time.
    If I was to go with traditional sanding what grit sequence would you suggest?
    Aug 2012
    DC
    755
    Have you tried a test spot? You might not need to sand it out. There are oxidation cleaners made for marine use. Most are acidic, but had just see it on ship shape TV. I'll see if I can find it.
    Oxalic acid is what was used to clean my fathers boat before we buffed it out. It made the buffing go much quicker, after cleaning it with the acid. Just be sure to wear proper PPE when working with it.
    Sent from my SAMSUNG-SGH-I777 using AG Online
    Oct 2012
    133
    If you sand 600/800 on up the darker the hull more steps.oxalic acid might help.Some folks even use muratic acid with good results. Do be careful with chemicals and read directions.Bar keepers freind is very cheap and will save time and money. I could go on and on about what to do and use but won't The Hulltruth an excellent source for boats restoration and real world explanations. I would say Autogeek is more auto question freindly.You would think with their new marine product launch they would focus on this fourm also. I think the amount of activities in this sub forum it's obvious you are on your own. 3m compounds and sandpapers are worth the extra money for your project
    Jan 2014
    Philadelphia, PA
    44
    Quote Originally Posted by STPETEDALE View Post
    Thanks for the reply.
    I'm going to research some more about the different acids.
    But I will post some pictures when I'm finished, will probably be a while. But I'll let you know how it turns out.
    I'll give some marine compound a try see if it has enough cut.
    I know marine compound has so much more grit than the auto compound so you never know.
    Aug 2010
    Fairmont, MN
    3,189
    What are you using as far as a "machine?" DA, rotary or "?"?
    Take a hard look at Meguiar's Marine Line (blue bottles). Power Cut (M-91) is hard core compound! It is recommended for rotary use, but it will work with a DA...just takes longer.
    Always try the least aggressive method first. In other words, hold off even thinking about sanding until you look at the 'compounding route'.
    Bill
    Jan 2014
    Philadelphia, PA
    44
    Quote Originally Posted by BillE View Post
    Bill
    I'm going to use a rotary with a wool pad.
    And I actually have a bottle of the M-91, I am planning to give it a try first.
    I'm debating about the oxalic acid though I don't know if it's worth using. As long as I get the hull clean before and then apply a coat of wax after the results should stay. . . Right?
    Super Member primo spaghetti's Avatar
    Jun 2012
    southern ontario
    763
    rotary and wool pad with aqua buff 1000. i would definitely try that before i sanded.
    I am the heir to the primo spaghetti sauce fortune
  10. #10
    Super Member master detailer's Avatar
    Nov 2010
    cape coral fl
    548
    1 you need to see if it is gelcoat ! Alot of these boats have been repainted with algrip that have alot more hardner in them and if you sand them you will not be able to buff out sand marks!!!!
    2 Take some 1000 grit and do a test spot if you get a milky color the same as the boat its gelcoat and then can sand it.I start with 1000 then finish with 1500.
    3 time to buff I use 1000 grit compound and it comes out like new. 4 use a good sealer/wax put on then let it dry buff off with foam pad at speed 2. your done.
  1. Video: First Training Boat Arrived - The REAL DEAL Boat Detailing Classes
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 02-03-2020, 03:18 PM
  2. Secured one boat for the 2019 Boat Detailing Class! - Still need one more boat
    Last Post: 10-24-2018, 03:39 PM
  3. Major Boat Scratch restoration
    By attention2detaillhc in forum Show N' Shine
    Last Post: 12-07-2016, 09:26 AM
  4. Boat fiberglass restoration
    By Coastalf350 in forum Boat & Marine Craft Detailing
    Last Post: 03-07-2016, 10:31 PM
  5. Replies: 14
    Last Post: 06-26-2011, 08:26 AM
