Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Aug 2010
    Fairmont, MN
    3,189
    Re: Gelcoat is boring
    Quote Originally Posted by KKYS View Post
    We never have problems with holograms in marine gelcoat.
    I would like to believe all gelcoat is the same, but it's not.
    We find that since boat builders use different manufactures of polyester/resins/pigments, they
    also finish out a little different. A Bayliner boat will need less aggression than say a Grady White.
    We don't have enough experience with RV's to give any advise.
    Totally totally agree!
    I 'did' a smallish boat summer that was beyond neglected, that lil puppy came out pretty darn nice (considering it was toast).
    I have a 5th wheel RV, and no way, in some areas, will that thing pop! To be honest, it is not what I'd call a 'good' gel-coat job.
    There are/is differences in 'fiber-glass'.
    Bill
  2. #22
    Re: Gel-coat is boring
    We never have problems with holograms in marine gel-coat.
    Lucky you....
    Just about every boat I've corrected, if it's been buffed by someone before me it has holograms. It's just most boats are white and most people don't even know what holograms are therefor they can look right at them and still never see them.
    Here's an example....
    How to wetsand, cut and buff a gel-coat boat
    Holograms in gel-coat
    The below picture is a full size section cropped out of the above resized picture. The lines you see running back and forth across where the flash from my camera is lighting up the side of the hull are holograms from a rotary buffer.
    And here's an article I wrote about holograms in the boat detailing industry.... from the lack of feedback I've had on the article on multiple forums, it's pretty easy to see the boat owners world and the boat detailing world are miles behind the car owners and car detailing world....
    Holograms in gel-coat boats
  3. #23
    Junior Member Showtime's Avatar
    Dec 2013
    Fort Lauderdale, Fl
    82
    I detail boats quite often and lately, when I'm doing some of these center consoles and walk arounds, when I do the gel coat around the cabin, I can't seem to get it perfect. There always seems to be "residue" left behind in certain lights in random areas. It's not residue as I've buffed it out with detail spray and it doesnt' come off. Am I working too fast? I usually use Marine 31 Heavy Oxidation Cleaner or this stuff called Super Cut that I get locally.
    Maybe I don't clean my pad often enough...no clue. But I keep it around 1400-2000rpms depending on how bad it is.
    Edit: I've never had this problem before....And I don't really think I've changed much. It has to be the pad washing not being done enough.
    Showtime Auto Detailing & Mobile Detailing Trailers
    http://detailbyshowtime.com
  4. #24
    Quote Originally Posted by Showtime View Post
    If it's not residue then is it just a dull or flat spot that didn't gloss up?
    What type of pad are you use and what type of tool?
  5. #25
    Feb 2012
    Ft Myers FL
    54
    Could it be that you didn't remove enough faded pigments
    in those areas. The polyester resins and pigments usually
    decay at different rates of time just because of the different molecular structure. The Color of the pigments also
    effect the rate of decay. I've heard some people call these dry or flat spots, but they are really just areas that were not cut deep enough into fresh pigment.
    Now the polyester resins may look good, shiny and smooth, but you may have to go a little deeper to get to fresh pigment.
    I don't know if that is your issue. Just a little info.
    There is a sand paper test you can do, if not you're not sure.
  6. #26
    Super Member Bates Detailing's Avatar
    Jan 2011
    Smyrna, Tennessee
    3,074
    I love turning around gel-coat! Haven't used a wool pad in ages it seems but to get that mirror shine it takes alot more time, effort, technique, and products than a one step and a rotary most of the time.
    Bates Detailing
    Auto * RV * Bus * Boat * Aircraft * UFOs
    http://www.batesdetailing.com
  7. #27
    Feb 2012
    Ft Myers FL
    54
    Quote Originally Posted by Bates Detailing View Post
    That is true . That is why understanding the amount of oxidation or just surface grim is important to a boat detailer.
    You can't depend on the manufactures label to constitute
    what is light, medium or heavy oxidation.. Because there is
    no real industry "standard".
    So it boils down to the individual detailers experience,
    as to the end result of keeping repeat clients.
    We always use wool when needed. There is no replacement for
    wool/rotary when conditions present themselves.
  1. Gelcoat Wax
    By Corey06 in forum Auto Detailing 101
    Last Post: 10-04-2017, 06:03 AM
  2. Dry gelcoat
    By Theraven in forum Boat & Marine Craft Detailing
    Last Post: 02-03-2013, 04:48 PM
  3. Gelcoat
    By NY-Bondo in forum Products Guides
    Last Post: 01-13-2013, 11:09 AM
  4. Something other than Gelcoat
    By KKYS in forum Boat & Marine Craft Detailing
    Last Post: 09-04-2012, 11:58 AM
  5. Front End Rebuild. BORING!!!
    By hoyt66 in forum Off-Topic
    Last Post: 07-04-2012, 07:07 PM
