» Detailing Classes
Results 1 to 2 of 2
Thread: Sanding
    Senior Member Theraven's Avatar
    Nov 2012
    110
    Sanding
    I've seen Mike use it in a video, what backing back and sanding discs can I use with the Meg's DA 110v2 polisher. Any tips for using the machine while sanding. Thanks in advance!
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Re: Sanding
    Auto Geek Online Auto Detailing Forum - Search Results
    This is a list of threads started by Mike.Phillips on sanding
    Should keep you in reading material until Mike gets to your post.
  1. How to refine hand sanding scratches by machine sanding - Mirka Abralon #3000 Sanding Discs
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 01-08-2019, 09:56 AM
  2. First time wet sanding kit - #3000 & #5000 Trizact Sanding Discs
    Last Post: 02-03-2017, 08:53 AM
  3. Replies: 2
    Last Post: 07-13-2016, 08:16 PM
  4. Dry Sanding & Wet Sanding with 3M's Flexible Abrasive Hookit Sheets
    Last Post: 09-24-2013, 08:14 AM
  5. Hand Sanding vs. Machine Sanding
    By Countersteer46 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-23-2013, 05:14 PM
» January 2020
293031 1 2 3 4
