Duragloss 561 & 501
I just ordered these based on several recommendations to use on mildly oxidized gel coat. I know to use a wool pad with the rotary for the 561 but what should I use for the 501? What speed for the wool and 561 would work best?? thanks
Re: Duragloss 561 & 501
You can use a white polishing pad for the 501.
Try out 1200-1400rpm with the wool and compound.
You definately want to use 601 with the 501 as it helps the cleaning and durability. I use a wool pad with everything on gelcoat. This time I changed it up a bit and used 601/501 with a wool pad and then topped with 601/105 with a white foam pad with a DA. My last ventiure was 652 then 601/105 all with a wool pad. A few washings with 932 and a few applications of Aqua Wax and a few applications of 932 mixed as a QD lasted a little over 1 year with minor oxidation. Sure beat the usual 3 month oxidation when using other products.
Dave
By RPPM in forum Auto Detailing 101
Last Post: 10-30-2017, 10:51 AM
By ROADRKT in forum Auto Detailing 101
Last Post: 01-19-2014, 09:17 AM
By magnum12 in forum Auto Detailing 101
Last Post: 03-25-2008, 10:44 PM
By Darren F in forum Auto Detailing 101
Last Post: 03-05-2008, 07:39 PM
By sirwaxalot in forum Auto Detailing 101
Last Post: 01-23-2008, 04:47 PM
