Application method
Is it better to apply product to the surface or the pad. I'm typically using a rotary and wool and or 50/50 yellow polishing pad.
Re: Application method
There's more than one way to "wet a pad" with product.
Just make sure to not dry buff.
What ever floats your boat.
I was able to pick up the bead with a PC and a Rotary. My Rupes on the other hand was unsuccessful. Unless your intentions are to splatter product, then the Rupes can easily do that job
I've noticed that when Mike Phillips works with a wool pad and rotary polisher, especially on gelcoats, he applies a bead of product and then picks it up using the 10 @ 10 (I think that's what it's called) method.
He is a firm believer of using whatever product you think works the best, but I have noticed that he consistently uses this method when working with a rotary polisher.
EDIT: I found the article that refers to the 10@10 method I talked about.
http://www.autogeekonline.net/forum/...ry-buffer.html
I prefer putting the product on the paint when using a rotary but as one said its really up to you being both methods works.
If you never tried "picking up a bead " then you may want to practice using this method , IMO it works best.
Mr. Mike Phiipps has a couple of vids showing how to do so,check it out.
I always prime my wool pad before I start a correction.
I experimented adding product to the pad and the results where almost night and day, compared to spreading it on the surface with an applicator. I was working on a dry, heavily swirled surface, so applying the product heavy to the pad worked the best for me ( with only minimal sling). Boats in better, picking up a bead would be a better option.
By CDot in forum Auto Detailing 101
Last Post: 04-28-2015, 04:01 AM
By richy in forum Tricks, Tips and Techniques
Last Post: 11-30-2014, 09:58 PM
By richy in forum Show N' Shine
Last Post: 08-29-2011, 07:16 PM
By CEE DOG in forum Auto Detailing 101
Last Post: 07-13-2009, 12:17 PM
By PowerstrokeFord in forum Auto Detailing 101
Last Post: 05-29-2009, 07:23 AM
