» Detailing Classes
Results 21 to 30 of 35
  1. #21
    Member RamAirV1's Avatar
    May 2012
    64
    Re: Help! My first detail project, and its a 26ft boat!
    That totally makes sense. Based on how I am going to use it, the G9 makes more sense for me. Right now I don't need to do any heavy correction. I still do have my Makita rotary, so there is that should I ever need it. And you already showed me how to use that (on my GTO). I have a new Scat Pack now (Destroyer Grey) and the G9 will be more than enough to handle the few RIDS that it has.
    RamAirV1
  2. Likes Aaryn NZ liked this post
  3. #22
    Apr 2020
    New Zealand
    Mike, Aaryn... Thanks again!
    My amazing wife has gone through all the pros and cons of the Makita vs Flex and she acutally WANTS me to get the Flex!! Looks like I will be learning the ways of the beast! Thank you both for your input, it has been invaluable helping me navigate the the minefield of options that a novice faces. I only have a one question before I start gathering bits and pieces for my detailing project.
    I have found the new Rupes wool pads that you shared with the blue fibers. I have a rotary tool I can borrow, however not for another two weeks due to the COVID lockdown in NZ and restrictions on inter-provincial travel. Mike, I found your article "MEGA pad selection for the FLEX 3401 - From Wool pads to Foam pad and even ABRALON SANDING DISCS" where it looks like you put a wool pad on the Flex. I like the comment that it will "turn and burn anything". Will the Flex spin the blue/white Rupes wool pad effectively enough to cut gel, or should I look for a cheap rotary in the mean time?
    Thanks again, and I look forward to sharing some images and feedback on my progress!!
    Kind regards
    Dan
  4. Thanks Aaryn NZ thanked for this post
  5. #23
    Senior Member Aaryn NZ's Avatar
    May 2012
    New Zealand
    1,927
    Nice one Dan!! Your Wife is awesome!!
    Send me a shipping address via PM & Iíll send you up some Menzerna compound to try out.
    Yes the BEAST will spin a RUPES wool pad or any other wool pad & it will indeed achieve good results, itíll just be a tad slower than the Rotary/DA double act but hey, if you have time on your side ... all good.
    Are you getting the Flex via RA Johnstone? Machine alone or the Malco Kit they have?
    Aaryn NZ.
    a DETAILS Blenheim New Zealand - IDA Member - C.Quartz Finest Authorized Installer
  6. #24
    Apr 2020
    New Zealand
    Wow Aaryn thank you, that is very kind! I will send you a PM
    Thanks for info on the flex/wool pad combo... TIME is one thing we all seem to have a little more of at the moment! I have to say there is a little bit of "new project" excitement building over this, or maybe it's just that I get to go shopping for a new power tools?!
    In terms of kits, that's a good question. I will probably focus on what I need for the job and not push my luck haha!
    Cheers
    Dan
  7. #25
    Apr 2020
    New Zealand
    Made it out of the house with the credit card today, though I would post a picture of the damage...
    Help! My first detail project, and its a 26ft boat!-shopping-blur-jpg
    Tools and pads as follows; Flex 3401, 2 Rupes rotary wool pads (will try these on the Flex), 6 Rupes coarse blue pads, 2 Rupes ultrafine pads (to polish the isinglass on the boat), some Rupes Zephir Gloss Coarse, and some UV wax (label blanked to respect the forum rules).
    I would like to say a HUGE THANK YOU to Aaryn NZ who has gone out of his way to help me locally here in New Zealand. He has even sent me a sample of the product he uses in his detail shop to try, along with making calls to track down a Flex on my behalf. Awesome stuff!
    Thank you to Mike Phillips as well for all the product testing and suggestions! This has, without question, cut down on the pain I would have endured trying to figure all this out on my own!
    Give me a few days to figure out how all this stuff works and I will be back with an update, and hopefully something others might one day find of use!
  8. #26
    Jun 2009
    Stuart, Florida
    46,919
    [QUOTE=Dan NZ;1673727]
    Here's the deal, any traditional wool pad will work on the BEAST - BUT - unlike a rotary polisher that spins in a circle, due to the 8mm oscillation action - you won't be able to get as close to an edge like a rub rail as you could a rotary. So just be aware of this when your sanding.
    What I practice and what I teach in my wet sanding classes is,
    DON'T sand where you cannot buff
    Otherwise- you'll be trying to work your sanding marks out by HAND.
    Also - I don't know why, it could just be my fault from PUSHING the BEAST too hard when buffing with wool pads - but when I use these types of pads on the BEAST it seems to generate a LOT of heat at the backing of the pad and this can lead to de-lamination of the adhesive between the velcro on the back of the pad and the pad liner. So don't full mad man when using the FLEX for compounding out sanding marks.
    If it were me - I would stick with a rotary buffer to remove sanding marks and use the BEAST to remove holograms and polish to a clear, high gloss. This is a great combo.
    Quote Originally Posted by Dan NZ View Post
    Sounds good. And remember - before going full comando on your boat - START WITH A TEST SPOT.
    Test the PROCESS you think, hope, dream and pray will work on the boat to one small area all the way through from start to finish and then inspect the results. If you cannot make one small area look good you won't be able to make the entire boat look good.
    The good news is - if you can make one small area look GREAT - you can make the entire boat look great. Sometimes you get close and all you need to do is tweak your technique.
    I told you so - he's a great guy and a great resource.
    Ah shucks.... I just do what I always do - help the world removes swirls one car at a time and in your case, one boat at a time.
    I'm already looking forward to you next post.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  9. Likes RamAirV1 liked this post
  10. #27
    Apr 2020
    New Zealand
    Just a very quick update!
    The weather is turning and it may be a week before I can start the polishing of my boat, however I am impatient so I had to power up the flex for a quick go! Cant get a new power tool and not at least turn it on?!
    I don't have a rotary yet, so this is the result of the Rupes Zehpir and the Rupes coarse blue pad directly on the oxidized gel, plus some wax.
    I guess white/light coloured gel doesn't reflect like the darker gels, however I am very happy the result!
    Grady Whites are not white at all, but a slightly cream/tan colour, and the photo doesn't do the restoration of colour justice! It is like night and day in person.
    I am sure I will get better results soon as my feel for the tool and pad develops, plus tool control. This was on speed 3 with the tool rested (not pressed hard) against the boat...
    I think I can go faster and use more pressure but baby steps first! Also looking forward to another attempt with a rotary and wool pad.
    Cheers for now!
    Help! My first detail project, and its a 26ft boat!-polish-test-jpg
  11. Thanks Aaryn NZ thanked for this post
    Likes Aaryn NZ, RamAirV1 liked this post
  12. #28
    Jun 2009
    Stuart, Florida
    46,919
    Looks good Dan!
    Like I tell people, gel-coats DON'T like soft mushy pads for polishing. They like a hard, sharp foam pad and I have not found a pad that works better than the RUPES coarse blue foam pads for the POLISHING step.
    This is why I always teach these pads in my boat detailing classes. You can get "show car results" in the finish on a boat.
    Also - might go against the average person's thinking - but when polishing gel coat, (after correction), spin those RUPES pads on the highest speed setting and on your last few passes - REDUCE pressure - DON'T maintain pressure.
    Polishing anything is an art form.
    And getting GREAT results ALWAYS starts with GREAT abrasive technology. So many guys think it's all about THEIR technique. That thinking is EGO-DRIVEN. Sorry to disappoint whole lot of Alpha Male detailers but YOU are NOT touching the surface - the abrasives are.
    Abrasive Technology - THE most important factor when it comes to polishing paint
    But according to my own poll.... I'm wrong....
    POLL - What's the number one most important factor when it comes to polishing paint?
    Thanks for sharing!
    Twitter
    Instagram
  13. Likes Aaryn NZ liked this post
  14. #29
    Apr 2020
    New Zealand
    Smile Re: Help! My first detail project, and its a 26ft boat!
    Thanks Mike!
    If you ever need proof of this (and I know you don't), then all I can say is look at me. I have almost zero technique having only logged only about 3 hours on the buffer, however the results I have obtained by following the formula have exceeded what I thought possible. With improvement in technique I am sure my results will improve as I put the abrasives to work more efficiently. I have been lucky to get some time in between passing showers of rain, and thought I would post some more progress. I have done about 1/4 of the boat so far, but my progress will slow as I tackle more complex areas of the boat. I am not a shortcut guy, and I will soon start removing and replacing components and opposed to trying to buff around them. I see another 4 full days work ahead and a LOT MORE learning.
    I started polishing the hull sides as these already had a wax shine compared to the chalky topsides, and thought this would be a good place to start as I don't have a rotary. In the picture below I have polished from the left side of the frame up to the red line, the right side is in "original" condition. While both sides look reflective from a distance, an up close image reveals the truth!
    Help! My first detail project, and its a 26ft boat!-pollish-1-jpg
    This is the polished area
    Help! My first detail project, and its a 26ft boat!-pollish-2-jpg
    This is the unpolished area which looks shiny from a distance, but dull up close.
    Help! My first detail project, and its a 26ft boat!-pollish-3-jpg
    Taking a photo at a shallow angle is probably cheating, however I have a very narrow work area in places and this is the gap I squeeze through coming from the garage. When I turned back towards the boat after buffing out an area, this is the view I had from the garage and I WAS BLOWN AWAY with the results that the Rupes pad/polish combo had produced! Total time on the Flex at this stage... About 45 minutes!
    Help! My first detail project, and its a 26ft boat!-pollish-4-jpg
    Moving to the topsides I thought I would have a go with 2000 wet and the Flex/Rupes Coarse combo. The Zephir Gloss Coarse says it will remove 1500 grit sanding marks. I don't have the lamps/eye for scratches and defects that many of you here will have, but from what I can see the combination had no issue with the 2000 grit. I will concede that there are a couple of areas that will need a second go, but it would be an understatement to say that I am happy with the results. Left frame is polished, right frame is in original condition.
    Help! My first detail project, and its a 26ft boat!-pollish-6-jpgHelp! My first detail project, and its a 26ft boat!-pollish-7-jpg
    Now for a question! This was the condition of the pad after about 2 hours of intermittent polishing (with a couple of dabs of new polish added). I polished one more section with it, then put a new pad on. Have I gone past the point where I should have swapped the pad out? (I have 6 pads).
    Help! My first detail project, and its a 26ft boat!-pad-1-jpgHelp! My first detail project, and its a 26ft boat!-pad-2-jpg
    I hear people say that the Rupes Zephir Coarse makes a lot of dust. I didn't notice any dust at first, but once I began to use less compound and more seed (5 on the Flex) I did notice that I created quite a lot of dust. This doesn't bother me, however I wondered if it was a sign that I was starting to use the pad more efficiently? There were a couple of moments where I was finishing a section out and most of the compound had started to 'dust off' leaving more of a shine in the wake of the pad than a trail of wet compound. Is this the sweet spot when finishing a section, or should I be aiming to keep things 'wet' (for lack of a better description)?
    Oh, following the advice that Rupe make on cleaning the pads (soak in water until wash time, then machine wash with unscented detergent and 1/4 cup vinegar), all the pads and buffing cloths came out like new! I cannot notice any deterioration in the pads, except for the edges of one were I clipped the fuel vent with the 'ghosting' part of the pad. Do these pads actually ware down, or do they just become dull over time while retaining their volume/shape? How does one determine the service life of such a pad?
    Thanks again in advance, and I am already eying up smaller detailing tools for tight nooks and crannies. No one warned this detail thing could become a slippery slope....
    Kind regards to all!!
    Dan
  15. Thanks Aaryn NZ thanked for this post
  16. #30
    May 2012
    New Zealand
    1,927
    Dan buddy, youíre killiní it.
    Look at you kicking @$#. It looks like itís coming up a treat. Great job mate.
    In regards to your picture of the pad, yeah, Iíd say you did good. Iím impressed at the number of pads you picked up, I know ďDetailersĒ that arenít willing to invest in enough pads, so big props to you. Pads do wear down & youíre going to figure it out when itís time to bin them ... I havenít any pictures to display a pad that I would deem expired but someone else may chime in with one so you have a visual reference.
    If you take care of them they will last a good while & youíll definitely get your moneyís worth out of them.
    Hahaha, itís sounds like youíre hooked .... we got him guys! Another one on the brink of addiction to detailing. Let me know if I can help you out with your search for more tools too.
    Iím impressed my friend, keep up the great work & hopefully the weather will play nice. Lots of rain for me today & temperatures have dropped this afternoon & thereís a dusting of snow on the ranges ... time to move to Florida I think ...
    Aaryn NZ.
  17. Thanks Dan NZ thanked for this post
    Likes Dan NZ liked this post
  1. Boat Video Project - Restoring the Gel-coat on a 21' Cougar MTR Tunnel Hull
    By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
    Last Post: 05-23-2019, 09:53 PM
  2. Project XJ - Interior Detail
    By TTQ B4U in forum Show N' Shine
    Last Post: 02-05-2019, 07:22 AM
  3. Secured one boat for the 2019 Boat Detailing Class! - Still need one more boat
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 10-24-2018, 03:39 PM
  4. Project detail trailer
    By Compulsive Detail in forum Auto Detailing 101
    Last Post: 04-16-2018, 12:30 PM
  5. 2-3 guys needed - Pontoon Boat Project - Tomorrow! (Wednesday)
    Last Post: 05-21-2015, 10:00 AM
Members who have read this thread: 69
» July 2020
