Results 1 to 5 of 5
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    BF One Step cure time?
    Are you guys and girls wiping this right off or are you letting it cure a bit for the sealant to take hold?
    The directions do not specifically say. I think I remember someone saying it needs to cure but I couldn’t find the post.
    Jim
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: BF One Step cure time?
    Never used the BF, but I have read numerous comparisons to Speed.
    If it's as close as they say, I'd let it "cure" as you mentioned, to let whatever LSP they use adhere better
    I've never had a problem applying Speed to the entire truck, then removing it afterward.
    May 2017
    Pittsburgh PA
    2,847
    I believe the sealant in One Step is the same as Blackfire Paint Sealant, which only directs the user to wait until a haze forms to wipe off. I've also read that as far as actual cure times after buffing off, the wet diamond polymers are one of the faster cross-linking types, and under low humidity and decent temperature, 90-something percent can typically cure within an hour or two. This being the amount of time before one should layer or get it wet.
    This makes me think that whether you wait to buff off or buff off as soon as it dries, either way the polymers should be bonded enough for the purposes of wiping off. If it is a more humid, hot day, you can always take caution and wait longer.
    Super Member lane5515's Avatar
    Mar 2013
    Fargo, ND
    660
    I polish the whole car with it and wait about an hour after finishing to wipe it off. I don't know if it's right or wrong but it works well for me.
    2018 Ford F150 - Ruby Red Metallic
    2019 Honda Odyssey - Obsidian Blue
  5. Likes PaulMys liked this post
  6. #5
    Regular Member Stevedotmil's Avatar
    Feb 2013
    Columbia, SC
    118
    When you do so what is the difficulty level in removing the product?
    https://www.facebook.com/newfinishPDLLC/
    Steve Infante, New Finish Columbia 803-553-1782
    Columbia, SC / IG:@newfinishcolumbia
  1. Cure time?
    By Don M in forum GYEON Car Care Products
    Last Post: 06-26-2018, 10:31 AM
  2. Cure time?
    By scorey in forum Auto Detailing 101
    Last Post: 12-02-2013, 02:52 AM
  3. Cure time
    By octane in forum Auto Detailing 101
    Last Post: 06-06-2013, 05:59 PM
  4. cure time
    By wisemonkey in forum Auto Detailing 101
    Last Post: 06-26-2008, 06:50 PM
  5. Cure Time
    By Darren F in forum Auto Detailing 101
    Last Post: 07-15-2006, 06:31 PM
